THE BELOW IS BORING TO MOST BUT NOT TO YOU CLASSIC MOTORHOME NUTS!
Changed the oil and made much less mess than the first time. Oil is still real black. It may take a few more oil changes to remove the lack of care of the previous owners. I also changed the air filter even though it really didn't need it.
I worked on the hose reel to get the new hose on. I couldn't get the bolts off the bottom of the compartment. I still can't see any way to accomplish this without taking off the compartment bottom.
Armed with my new dump valve from Andy at Inland, I removed the gray water valve. The pipe is attached via PVC cement. Instead of using the new valve, I completely took apart the old one and gave it a thorough cleaning. Only the rivits that hold the arm are missing. I'll get two stainless steel screws for that. I had the wife fill the gray water tank with the garden hose. No leakage at the valve or into the dump tubes.
My Sunday work involves removing the batteries, cleaning the batteries, cleaning the compartment, removing rust, painting with rust primer.
The hose reel is still unresolved. I think I'm ready for professional assistance.
