Old 09-05-2015, 06:08 AM   #15
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
One more reason for a fire suppression system...need I say more.Click image for larger version
Name:	ImageUploadedByAirstream Forums1441454865.123410.jpg
ID:	247300Click image for larger version
Name:	ImageUploadedByAirstream Forums1441454883.456266.jpg
bobmiller1 is offline   Reply With Quote
Old 09-05-2015, 11:24 AM   #16
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Really great work Bob. Did you do all the piping yourself? I like your setup because I could have one larger tank and heads for the motor bay and generator.
SebasSF is offline   Reply With Quote
Old 09-06-2015, 07:44 AM   #17
bobmiller1's Avatar
Yes, that is the longest part of the job, running the lines. Bend, install,remove,bend again,install again,adjust etc.etc.etc. when that is finished then the lines have to be pressurized with air to check for leaks. if there are no leaks then you can charge the system with the AFFF. Hopefully mine will never be used but if it is I know that the worst thing I will be facing is a tow back to my shop. The thought of an engine fire really bothers me because of the location of the engine and the door to exit. As you know time is of the essence under those circumstances and you must be able to take care of yourself in that situation.
Old 09-06-2015, 10:29 AM   #18
lewster's Avatar
Naples, FL , Hood River, OR
Don't forget that your gas-absorption RV fridge also has a high potential as a source of fire!
Old 09-09-2015, 08:30 AM   #19
StarLord's Avatar
2008 23' International
1979 28' Airstream Excella 28
Pinson , Alabama
Fire Protection System
I've been reading the same about MH's going up in flames. Amerex Corporation has a Small Vehicle Fire Suppression System (SMVS)which have been installed on Para Transit Vehicles, Shuttle Vans, Vending Delivery Vans and many other makes.
Features: Manual Fire Suppression Release on Display Face, 1 Hr Battery backup using standard 9v battery, audible trouble and fire alarm, vibration resistant detection design, two heat detectors and two nozzles, rapid response heat detection, Uses Existing Amerex Linear Actuator, 10VDC to 30VDC operating voltage, Internal Relay for engine shutdown, low power consumption 60ma,13.2 pds of ABC dry chemcial powder The system cost appx. $1750 to $2000.
To answer your next question - No, I'm not a salesman. Found it on line and even better I discovered their headquarters is only about 10 miles from my home. I've driven by this place for many many years and never questioned what Amerex Corp made. I met with the Alan Fulton, Project Manager of the system, saw video's and was impressed.
Amerex Corporation, 7595 Gadsden Hwy, Trussville Alabama 35173 (205) 655-3271 or http//www.amerex-fire.com
StarLord is offline   Reply With Quote
Old 09-11-2015, 07:21 AM   #20
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Just food for thought, years ago I had a big truck catch fire because of a shorted battery cable, I exhausted a 2 pound dry chemical extinguisher, two 5 pounds, and half a ten pound extinguisher getting the fire under control.
I guess what I am saying is make sure you use as big a supply as practically possible. Fire is a worthy opponent that isn't always easily thwarted.
Valley of Fires and White Sands Monument 2013 Rally Alumaholic WBCCI Rallies & Events 6 09-24-2013 04:20 PM
Valley of Fires and White Sands Monument 2012-2013 Alumaholic WBCCI Rallies & Events 14 09-19-2012 11:21 PM
Central Texas Fires and Bastrop State Park lcurrie Off Topic Forum 35 09-14-2011 03:37 PM
