Old 01-07-2016, 05:13 PM   #1
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
Mini blind boxes
I am trying to locate some boxes for the blinds in my 1987 345 living room and bedroom like soClick image for larger version
Name:	ImageUploadedByAirstream Forums1452211907.128901.jpg
ID:	255294. To cover these types of things Click image for larger version
Name:	ImageUploadedByAirstream Forums1452211941.356797.jpg
ID:	255295 I believe I would need three sets minimum and ideally five sets. This may be posted in the wrong section but the app didn't show a section for motorhome interior parts wanted.
Kreimer is offline   Reply With Quote
Old 04-12-2017, 07:49 AM   #2
jkwoodrow
Springfield , Ohio
The kitchen window was the only blind with the finished wood box or valance or whatever you call it. All the other blinds were finished on the ends with velour drapery panels. The original wood blinds were nice except when driving. They clang and bang and are a real nuisance. My answer to all of that was to ditch the drape panels and original blinds. I had all of the windows tinted and mounted retractable Levelor blinds cut to length from Lowes. I did leave the original set up at the kitchen window and the original mini blinds in the back.
The Levelor blinds work perfectly and retract completely out of the way during the day and totally eliminate the flapping and banging around. They provide privacy when needed and insulate heat or cold radiating from the windows. It's been a welcome addition to the 345 and was very cheap as projects go.
John Woodrow is offline   Reply With Quote
Old 04-12-2017, 08:03 AM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Technical name is lambrequin window close outs (I think). There are a couple of coaches being parted out, which might be miles away, but you could try them if prepared to travel.
Boom Sounds is offline   Reply With Quote
Old 04-12-2017, 02:15 PM   #4
Maybe they were on the trailers as well
Changing the roll-up shade in the door of a 1987 Excella to a mini-blind blkmagikca General Repair Forum 1 07-13-2015 09:10 PM
Where to buy OEM mini blind hold down clips for 2008 airstream? bonginator Upholstery, Blinds, Walls & Interior Finishes 12 08-01-2014 07:49 AM
Mini-Blind between the window and screen mopariac Upholstery, Blinds, Walls & Interior Finishes 6 06-07-2013 08:16 PM
Plastic mini-blind clips Snaken49 2009-2015 Flying Cloud 0 03-14-2013 03:44 PM
Mini blind cord stops source idmtman Upholstery, Blinds, Walls & Interior Finishes 2 11-30-2011 12:56 PM
