Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 08-26-2002, 09:15 AM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Microwave not working
I have a Sharp Carousel microwave/convection. It's boxed in pretty good. After making New Orleans style dirty rice for 25 minutes, it completely shut down. The cabinet around it was really hot. No smoke smell. No lights, power, nothing. I tried resetting the breakers (none were popped). It is bolted down. My next step is to take it out and try it outside the RV. I also need to test the electical socket.
Should the box be better ventilated? The food stored in the cabinet above was pretty hot. Has anyone drilled ventilation holes in the side wall?
To make matters worse, the rice was too spicey for our taste.
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 08-26-2002, 09:43 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Fred,
Is there a vent grate above the microwave itself? There is a need for air movement for proper cooling of the microwave. If there is a vent, did any air come out of it when the microwave was working? After you pull it out, I owuld have a appliance shop check for a blown fuse. It just may have never been worked that hard before. I would also check the ventelation and air gap around the unit itself. there should be enough air flow to keep it cool enough to not die from the heat! You may also find stuff has fallen into or down from above and created an insulation effect.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-26-2002, 11:16 AM   #3
1985air345
1985air345's Avatar
There is no grate anywhere! No above, below, behind, or to the side. There is only a 1/8 inch gap around the unit on the sides and top. The bottom has a 1/4 gap. My manual shows a vent in the top rear. I'll know more when I pull it out. If I get it working, you can be sure I'll cut some ventilation holes.
Look at 1984 345 (A) on my site. It's not mine but you can see how tight they have that micro in there.
All the new micros have a ventilation grill above, below, or both.
Fred H.
Old 08-26-2002, 11:29 AM   #4
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Talking
It was that rice. You know there is relationship between Cajun food and microwaves. You need an open pit, or bah-b-que
My microwave has the vents built in to the lower front side. I think it is as old as my coach.
Old 08-28-2002, 02:08 PM   #5
1985air345
1985air345's Avatar
I pulled out the microwave last night and there is no ventilation behind it. The unit does have vents in the rear (the vents to nowhere.....).
Well, I did test the AC outlet and it tested good.
I took the unit home and opened it up. Bought two new fuses today - which it promptly blew seconds after starting it up. I guess it's time for a new microwave. This unit was manufactured in October of 1984. I guess it's time.
Fred H.
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 10:02 AM
Installing a microwave in 1976 Overlander? tin can luv Interior Restoration Forum 8 01-31-2004 08:09 PM
Level sensors - not working drboyd Waste Systems, Tanks & Totes 3 12-06-2003 07:16 AM
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 0 10-21-2003 09:41 PM
microwave in a 66 safari? kc airstreamer Stoves, Ovens & Microwaves 4 09-15-2003 08:58 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
