Old 08-16-2003, 08:22 AM   #1
Send a message via AIM to will Send a message via Yahoo to will
Master Cylinder Replacement
The master cylinder on my 89 345 has been leaking for a while now and I am concidering replacing it myself.Is there anyone who can offer any tips on doing this? Does anyone know the Gm replacement part numbers for the master cylinder and booster?
will is offline   Reply With Quote
Old 08-16-2003, 08:39 AM   #2
jaiman's Avatar
Images: 32
My 81 was a breeze. I went to Napa and they had it in stock. Around $20 if I recall. YOu will need another person to assist when bleeding the system. (which did take some time as mine got full of air and moisture) Remember to do the right rear first then left rear then right front and finally left front. This is assuming the Master Cylinder is on the left side of your engine. Check the reservoir often as you are bleeding. I had to use a mirror to check mine. I was told to use only GM fluid but when I went to GM they said they never use it and sold me Napa. Go Figure.
Jai
jaiman is offline   Reply With Quote
Old 08-16-2003, 06:33 PM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
ive replaced a few master cylinders but i didnt call the one on my coach a breeze. you have to take the drivers side tire and fender well off and then it is almost dueable. if you have paws like i do it is a hard job to get the bolts in the holes they need to go.
also get a puller to take the pulley off if you mess the pulley up my good wrench will get $35 for another . dont even dream about a hammer you will mess the new pump up and possibly the pulley. also when you put the pulley on dont press it all the way in as you need the room to put in the last bolt. but not to worry they provide a bolt and washers to tighten the pulley down and that is the easy part. if i had to i think i would replace mine again as i wouldnt trust some of these mechanics to do the job. my pully came apart and i was in the middle of no where. when you lose the power sterring pump you also lose the brake boost. yea you still have brakes but not much. i got 1/2 mile from home and some joker pulled in front of me and i almost got him . i couldnt see his bumper and that is close.
if you pump is going bad best be doing sumpin about it.
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 08-16-2003, 06:35 PM   #4
wb13798's Avatar
2004 28' Classic
may not be too bad with the serpitine belt dont know. you will have fun.
al
AL
allison 6 speed
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
