Old 03-13-2017, 05:21 AM   #1
2017 Interstate Grand Tour Ext
St Petersburg , Florida
lug nut wrench
Hi Guys!
We're still getting used to all the bells and whistles on our 2017 ASIGT 4x4 and discovered that the lug wrench supplied by AS is 19mm whereas the lug nuts on the wheels are 21mm. Check yours out. It could evolve into an unsafe situation.
We'd love to hear from others about issues with their 2017 Interstates, particularly,
calibration of grey water tank, chassis squeaks, inaccuracies on Certified Performance checklist.
Hilton
Hilton is offline   Reply With Quote
Old 03-13-2017, 09:15 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Only the trim covers on the lug nuts are 21-22mm. The actual lug nuts under the covers are 19mm. See attached photos
- - Mike
Old 03-13-2017, 10:10 AM   #3
Lug nuts
What is best way to remove lug nut covers without damage?
Old 03-13-2017, 01:10 PM   #4
Fulton , Maryland
I got adjustable lug nut cover pliers like these:
https://www.amazon.com/Roadmaster-10.../dp/B000XPUT0S
Most of the non-adjustable version are too big for the smaller covers on the Alcoa wheels.
- - Mike
Old 04-17-2017, 07:45 PM   #5
1997 35' Cutter Bus Diesel Pusher
PEARBLOSSOM , California
I had the same problem; the adapter nuts for the DOT hubcaps on my 35' Cutter were frozen. After breaking a Snap-On wrench trying to get them off, I went and bought a Milwaukee battery powered impact wrench and sockets to fit both the adapter nuts and lug nuts. Unbelievably, the battery power wrench could more than handle all frozen nuts, I've even used it to remove the U-bolts holding the front axle in order to change the airbags. I won't go on the road without some means to change a tire, just seems appropriate.
jerryemeryde is offline   Reply With Quote
Wrench for lug nuts Dingo Girl Wheels, Hubs & Bearings 0 11-30-2016 04:32 PM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Lug wrench - sizes? Jammer Wheels, Hubs & Bearings 16 01-27-2010 09:56 AM
Lug wrench incl. with AS is useless temcotom Wheels, Hubs & Bearings 18 10-30-2004 11:22 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
