Join Airstream Forums Today
Old 12-05-2011, 07:45 PM   #1
2004 39' Land Yacht 390 XL 396
Bowie , Texas
Losing engine elec. engine dies while driving
I lose electrical power just driving down the road. all light go out, no emerg. flasher... nothing until I turn the key off and back on a couple of time. Rough road, smoth road, up hill, down hill, doest mater. I think its a bad ground or bad ignition. Any ideas?
ccgartman is offline   Reply With Quote
Old 12-05-2011, 07:50 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
Welcome to the forum. If nothing works until you cycle the key, chances are good it's the ignition switch. Cleaning grounds and other connections won't hurt, either.
Some days, it's just not worth chewing through the restraints.
Old 12-05-2011, 09:30 PM   #3
Common Sense , Texas
Not saying this the problem, but a friend of mine had a hot rod that did the same thing. Turned out to be a cold solder joint in the main battery ground cable to the block of the engine.
I would check all such cables/connectors/joints, including the ones on the ignition switch. The easiest way to find the problem would be with the engine running at idle, and wiggling wires/connectors to see if you can find one that makes it quit. Good luck, and welcome to the forum, CC.
Old 12-05-2011, 09:39 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Key or relay the key triggers, does it also kill engine, being diesel, old ones would go even if you didn't have alternator and batteries, new without electric the computer shuts it down. My guess would also be battery main ground if engine dies too.
Old 12-10-2011, 08:46 AM   #5
Bowie , Texas
Thanks for the help. I found the problem. It was a 135 amp auto reset breaker located in the same box as the inverter. 15min ($40.00)replacement job.
bad ground, engine dies, power
How to get to engine on rear diesel pusher? 442 john Land Yacht/Legacy Motorhomes 1 10-21-2011 10:26 AM
Replace engine in 95 LandYacht Diesel cjshaffer2 Land Yacht/Legacy Motorhomes 4 09-25-2011 07:40 PM
Driving Tips, '89 325 joelforeman Classic Motorhomes 8 09-19-2011 10:27 AM
Engine box Fasteners, Bolts, 1995 Cutter LE on Ford F53 Chassis BarnacleBill Land Yacht/Legacy Motorhomes 4 04-27-2011 03:41 PM
