Old 09-19-2018, 12:14 PM   #1
1991 35' Airstream 350
Georgetown , Kentucky
Looking for help on 350LE roof Spotlight
Dear Forum-
Im trying to replace the spotlight on the roof of a 1991 350 LE Classic but I cannot find the bulb. Camping workl lost the old bulb I had in it and the parts number was unreadable. I cannot find the parts number anywhere on line or in any manuals. Can anyone provide me a parts number for the replacement bulb or a place to find an appropriate bulb to replace this? I know the correct bulb has to have 3 prongs (terminals) and is about 4.5 inches in diameter as the internal diameter of the light fixture is 4 5/8".
Camping world also lost the external trim ring for the spotlight that holds the bulb in the light fixture. Does anyone know where I might find a replacement for this?
thank you in advance.
Bradford Bentz
Bentzb02 is offline   Reply With Quote
Old 09-19-2018, 12:33 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Try this outfit. https://www.go2marine.com/product/21...42-series.html
Cheers, Dan
~ Margaret Thatcher ~
Old 09-24-2018, 03:03 PM   #3
Magnet18's Avatar
Churubusco , Indiana
Let us know if you find the right bulb amd how it works out
Mine needs replaced as well, considering creating a custom LED setup if it's NLA
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 09-25-2018, 12:28 PM   #4
Airstream spotlight 1991 350 LE
could not find the correct bulb anywhere. Internal diameter of bulb measures 4 5/8". I did find a bulb that size with only 2 terminals instead of 3. It is exactly 4 5/8" so im not sure if it would really fit as it should. Its called a Sea-Dog Round Spreader Light Replacement Bulb. Its at Go2Marine.com. The bulb dude said you could use a 2 terminal bulb if you just hooked both the flood wire and the spot wire to the same terminal and the ground to the other. You would onlyhave one light mode obviously then.
However, after all of this, I have decided to just replace the entire spotlight with something similar but that I can actually find bulbs for. Im replacing the original light with another hardwired spotlight by KHIndustries. NightRay 475-20 vehicle mounted spot/flood light 4.5" in diameter.
Brad Bentz
Old 12-19-2018, 01:17 PM   #5
Tucson , Arizona
I recently replaced my spotlight on my 1985 345. I used Oasis RV in Tucson AZ, they are actually listed as an authorized Airstream supplier in the original service manual. If you were googled/called them, I'd bet they could ship something to you.
At Least they could tell you for sure what size you needed....
Todd
Toddnazus is offline   Reply With Quote
Looking for vintage Airstream to spotlight at show awetsch Our Community 0 11-20-2014 04:09 PM
Remote spotlight- adjusting the vertical travel? Alechemist Classic Motorhomes 0 07-28-2014 08:47 AM
Rodent steals the spotlight kevin242 Fun & Games 3 08-15-2009 05:06 PM
Mechanic Spotlight! Airhog1 Commercial Listings 1 06-01-2007 07:45 PM
Replacement Bulb for Remote Spotlight? swebster Classic Motorhomes 3 06-17-2005 01:06 PM
