Old 09-26-2003, 07:28 AM   #1
AIRFORUMS # 005
ALANSD's Avatar
1966 26' Overlander
North , Georgia
Send a message via Yahoo to ALANSD
Leaf Springs
saw an interesting tip on maintenance of leaf springs. They said to remove rust from the exterior with a wire brush, then paint the springs with rust prventive. Then when dry you apply a layer of grease to the spring frcing it in with your hands, and wrap the whole thing in duct tape for awhile. After driving it for a few weeks you remove the tape.
Suppose to improve the spring performance. Whaddayathink?
Old 09-26-2003, 08:02 AM   #2
LOST , Hawaii
If nothing else they look better cleaned and painted. But with what a spring goes through it seems like a waste of time to grease them; failure is usually from breaking or losing their arch. With the pressure on them I don't think the grease would really penetrate too far between the leafs. If you want to lube them use a spray lube that will penetrate and not attract crud as much.
John
74Argosy24MH is offline   Reply With Quote
Old 09-26-2003, 08:09 AM   #3
Images: 59
Springs
What great timing! I'm going to a spring shop today to get prices on new springs. Should I ask about chrome?
Old 09-26-2003, 10:03 AM   #4
AIRFORUMS # 005
ALANSD's Avatar
1966 26' Overlander
North , Georgia
thats what I forget for watching the speed channel. I like the spray idea it sure would be faster and cleaner.
What about wheel bearings, any reason to grease them in between brake jobs?
Old 09-26-2003, 10:06 AM   #5
RichardT's Avatar
Re: Springs
I am sure you are kidding , but if not, No don't chrome leaf springs.
RichardT is offline   Reply With Quote
Old 09-26-2003, 10:09 AM   #6
RichardT's Avatar
Book says every 24,000 miles on wheel bearing grease and every 12,000 mi on rear axle oil change ,
Old 09-26-2003, 10:34 AM   #7
Images: 59
Re: Re: Springs
Darn it. that would look cool.
Old 09-26-2003, 11:55 AM   #8
Images: 59
Leaf Springs
EMCO in Oklahoma is coming out with aluminum coated leaf springs. Now that would be really cool!
Leaf springs markdoane Axles 2 09-27-2003 11:26 AM
Mystic Springs Bill Resseau Airstream Motorhome Forums 1 04-19-2003 08:39 PM
Mystic Springs 2003 rally!! thenewkid64 Forum Rallies & Meet Ups 41 04-02-2003 04:52 PM
New Springs for the old gal. 59toaster Axles 5 03-18-2003 12:06 PM
Brake springs. niftypkg Brakes & Brake Controllers 2 05-10-2002 07:01 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
