Old 02-17-2019, 12:13 PM   #1
2015 19' Flying Cloud
Remsenburg , New York
Land Yacht Brake Fluid Loss
Help!
I'm in a 2004 Airstream Landyacht (30').
Just checked in to Fort Clinch State Park in Fernandina Beach, FL. On the way to my campsite, brake pedal went to the floor and brakes failed. I can see that fluid is dripping under the engine, between the front wheels. Trying to get a mechanic lined up for a "house call" on Monday morning. I hope it's just a failed hose. Can anyone offer some insight to this issue while I wait for help to arrive?
wolos is offline   Reply With Quote
Old 02-17-2019, 01:26 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
When this happened to us last year the master cylinder had failed. On ours the leak was slow enough that I was able to refill with brake fluid and get enough pedal back to be able to drive for awhile.
Waipio Rim is offline   Reply With Quote
Old 02-17-2019, 03:10 PM   #3
1981 31' Excella II
New Market , Alabama
What type of Tow vehicle? It could be lots of things. It is either the master cylinder seal or a brake line has busted. If it is the master cylinder fluid will be leaking from the brake booster on the left side under the hood near the top. If the leak is somewhere else then it is probably a busted line.
Perry
Old 02-18-2019, 10:21 AM   #4
Perry, there is no tow vehicle. My Landyacht is a 30' motor home. I'm trying to schedule a tow truck for tomorrow morning to get my Landyacht to a service facility. I'll post again once it's fixed.
Old 02-18-2019, 12:40 PM   #5
2019 25' Flying Cloud
Hendersonville , North Carolina
Brake failure
When you do get to repair facility have all brake lines (rubber and metal) checked. At 15 years old (mileage does not matter) the system is at the age of needing attention. Brake fluid absorbs water so the entire brake system should be flushed every 2 or 3 years. Flushing the system also helps prevent seal failures in the master cylinder and calipers. Brake fluid also boils at a lower temperature when fouled with moisture resulting in loss of braking when going down that long steep hill. Maintenance 101. Hope you get fixed and back on road safely.
uraljohn is offline   Reply With Quote
Old 02-20-2019, 07:23 PM   #6
Uraljohn, thanks for your advice. The root cause of my issue was a rotted metal tubing section of my brake line. I had the piece replaced and then had the entire brake system flushed. Now I'm good to go. Master cylinder was ok. Thanks for all of the great advice.
Old 02-20-2019, 07:38 PM   #7
Brake failure fix
Glad to hear you were able to get repaired and everything checked. Safe travels to you and family.
Old 02-21-2019, 09:02 AM   #8
Magnet18's Avatar
Churubusco , Indiana
Just curious which section rusted out?
I've had that happen on a couple cars, while driving
when you have a good opportunity I'd replace all the brake lines with new stainless steel and new drop hoses, only a matter of time before another section goes.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-23-2019, 09:13 PM   #9
I'm not sure exactly where the rotted metal tubing was under my coach. The mechanic told me that it was part of the line connecting the rear brakes to the front brake line.
'94 Land Yacht power steering fluid drlegault Land Yacht/Legacy Motorhomes 9 09-18-2013 08:30 PM
Actibrake leaking brake fluid adonh Brakes & Brake Controllers 7 11-13-2011 06:12 PM
Brake Fluid Reservoir Barb H. Land Yacht/Legacy Motorhomes 2 08-08-2011 09:03 AM
Need help on how to access brake fluid reservoire on a 1997 airstrams cutter poloharvey Brakes & Brake Controllers 3 10-11-2010 11:28 PM
Brake Fluid Reservior Bedford Land Yacht/Legacy Motorhomes 3 07-15-2007 04:06 PM
