Old 11-09-2014, 08:22 AM   #1
Jacking up a 1979 Land Yacht
Hey folks, my built in jacks are rusted out. I am looking for insight on the best underbelly places to place new jacks. Afraid I might break through the fragile weathered bottom.
Thanks for insights.
michpete is offline   Reply With Quote
Old 11-09-2014, 08:49 AM   #2
SteveH's Avatar
Common Sense , Texas
I've never seen "built in jacks" other than the tongue jack, but your trailer may be equipped with bolt on stabilizers. Many people confuse them with jacks, but they are not for lifting, just stabilizing.
If I were going to replace them, I would try to find the exact same stabilizers and reattach them to the same place. In any event, they must be attached to the frame.
Welcome to the forum.
Regards,
Steve
Old 11-14-2014, 02:16 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Trailer or MH?
Old 11-14-2014, 02:27 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Do you mean stabilizers?
If you replace the stabilizers, you will remove the old ones and put the new ones where the were.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-23-2014, 08:29 AM   #5
Jacking up airstream
I suppose my real question is f I am placing Jacks underneath my land yacht, where is the most dependable and stable place to position them? I'm afraid I'll puncture the bottom. I have 6 jacks and would like to raise the vehicle high enough to have the wheels off the ground. Thanks for your insights.
Old 11-23-2014, 08:40 AM   #6
SteveH's Avatar
You only need two if they are big and capable enough, and are on stable footing such as concrete. Place them under the axle mounting plate on each side, and use the tongue jack in the front. If you have no tongue jack, use another jack stand under the tongue.
Actually using more than two might cause a unequal loading of the frame and introduce a twist.
I've removed all the tires and wheels from my trailers like this several times without problems.
Regards,
Steve
1979 Airstream Argosy Astrobus :: 1979 Airstream Astro Bus shaunamadre Airstream Registry Discussions 1 08-13-2012 11:56 PM
1979 Airstream Tradewind Land Yacht Excellent Condition eBay Watch Airstreams on eBay 0 09-27-2009 07:40 PM
Nice Unique 28' 1979 Airstream Land Yacht Sovereign!! eBay Watch Airstreams on eBay 0 06-03-2009 07:00 PM
1979 airstream international sovereign land yacht eBay Watch Airstreams on eBay 0 04-24-2009 05:50 PM
1979 Land Yacht jimclark1944 Trailer Values 5 05-25-2007 06:54 AM
