Old 02-27-2004, 08:38 PM   #1
pinopolis , South Carolina
Images: 30
Isuzu Turbo Diesel
What are the pros and com with the Isuzu diesel? Iam looking at a 30 ft 1981 . I think I would like to try a motorhome and sell the A/S trailer. Let me knowwhat yall think.
Fred
Fred is offline   Reply With Quote
Old 02-27-2004, 09:45 PM   #2
zduke4x's Avatar
some info
Only know that the Isuzu has a pretty good rep.....have only heard positives but am no expert, just a motorhome follower...cost of purchase and condition were my issues in buying..diesel is more durable and better mileage....lol..jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 02-27-2004, 11:44 PM   #3
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I like my Diesel. I get about 14 mpg. A little short on power up hell. It a good diesel.
alfalsetto is offline   Reply With Quote
Old 02-28-2004, 11:49 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
argreed with the above, also factor in a higher cost of maintenace than a gas engine, but less maintenance may be required if its a good one. Isusu has been long time owned by GM so parts are usually easier to find, and the duramax dielsel is made by them, so knowledge of working on those engines is almost as common as Chevy.
I would be careful to check out the motorho and trans, or have someone do it if you are not that knowledgeable. The other spots to check are suspension, air bags and all....and you already know how to spot problems with the coach part, just like a trailer in that respect.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-31-2006, 02:08 AM   #5
I am looking at purchaseing a 1964 Allegro 24 ft airstream motor home but unable to find any information, the engine is a GM v8 diesel these have a bad name for diesel engines here in Europe. The camper look the same as the early argosy with the curved glass sky lites help please are part available are the allegro and argosy basicly the same coach.
Mike
mike lis is offline   Reply With Quote
Old 08-01-2006, 11:15 AM   #6
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Mike,
Can you clarify for us, Allegro and Airstream are two different motorhome manufacturers here in the States and Airstream didn't start making the Argosy motorhomes until the mid seventies.
The GM V8 6.5 diesels have a reputation as dogs, non-turbo, underpowered, etc. They are however cheap, can be upgrade and came in many P30 chassis from GM.
Seems like the year, model and powerplant don't quite add up. Are you looking at a custom unit, or something retrofitted with a diesel at some point during it's history?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 03-24-2007, 02:47 PM   #7
The main problem with the Isuzu Diesel is that the Isuzu engine service groups like International truck aren't very good or cheap. The parts are hard to get and the horsepower is on the low side. If you can find an Airstream with a Cummins you will be much better off. You can also put a Cummins into an Isuzu rig. It will give you much more power, cheaper parts, more reliable service and service centers to pick from. Joe Popsil wrote about the conversion on this forum and I personally have done it to my 280 Turbo Diesel. It works great and I can cruise around 70 at idle. Struggling up hills is a thing of the past. The only thing you have to worry about is finding a reliable mechanic to do the install. You might expect Airstream to be some help since they made this a factory option but they only support the cabin structure and not the chassy. The diesel will give you more power, great gas mileage(14 - 17), longer life, and better reliability.
Mobile1 is offline   Reply With Quote
Old 03-24-2007, 03:46 PM   #8
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Where I live I can get parts all over the place. Different companies have whole fleets with the 6bd1 or newer engines and Allison transmissions can be purchased rebuilt right up the road from me.
I have driven Cummins, Detroit, Isuzu and Cat and haven't found any of them to deficient.
Now, for the money, I would take Cummins or Cat anytime. They cost a lot more though.
My izusu has one hundred twenty thousand miles and never had a wrench on it yet. I reckon it will go at least five hundred thousand before needing work. Spect I will some time, but right now I won't spend thosands to replace a perfectly good engine.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-24-2007, 05:28 PM   #9
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Cooperhawk & other Izuzu folk: Not the case of "my moho has ZZZZK" miles
turbo is always suspect, look for white to grey smoke. Injectors should be
pulled before bragging rights expire. Filters should be checked too often.
Airstreams have a fuel metering device mounted on the passenger frame
behind the manual bleed, which can also go south. Easy fix..except in B.F.
name your state.
Mike Leary is offline   Reply With Quote
Old 04-03-2007, 06:00 AM   #10
1983 31' Excella
JUPITER , Florida
Hello All,
Is there anyone with an AS diesel that is/has considered converting to WVO ?
I call myself ACETONE 'cuz I use it in our '92 MB 300 TD with great success !
The MB was getting 27 MPG when we got it. Started using ACETONE plus a basic tune-up - the MPG went to 35/36 MPG - - more over the road.
i don't want you to believe me. Go google it and find out what I did.
I'm seriously thinking of converting the diesel to WVO or at least a 'blend'.
Is there anyone out there with any knowledge - experience in this area ?
Also:
The engine in our 310 '83 AS is an Isuzu 351 6 cyl. TD.
All comments are invited.
Richard
ACETONE is offline   Reply With Quote
Old 04-03-2007, 09:02 AM   #11
Virginia Beach , Virginia
WVO conversion
To change to WVO it seems that you have to have a dedicated fuel tank for both the diesel and WVO, coolant line to heat up the WVO, a solenoid valve to turn on the WVO and turn it off, and remember to start the engine on pure diesel and make sure to turn off the WVO prior to stopping the engine.
Have to filter the WVO very very well, but that's just about it, other than making sure your supplier doesn't through too much junk in it, water, etc.
LOTS of information on the web, was thinking of doing this very thing to my wife's Jetta diesel.
vasellers is offline   Reply With Quote
Old 04-03-2007, 09:03 AM   #12
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I too have only heard great things about the diesels placed into Airstreams.
Old 04-03-2007, 09:23 AM   #13
The Hawk's Lair
cooperhawk's Avatar
My brother used Bio Diesel in his over the road White Freightliner for a time. I don't remember all the specifics, but he quit using it. I believe he said the mileage wasn't as good or the power either. There was also a problem running in cold weather.
Here in Minnesota we burn a blend of Bio and regular diesel in our Jedda Diesel with no problem. I find that the Izusu runs best on good old number two diesel. Best mileage and power.
AKA THE GUNNER
VFW, LEGION, NRA
Old 04-03-2007, 09:47 AM   #14
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
are all the seals in your fuel system and engine of a type that can withstand acetone?
Michelle TAC MT-0
Sarah, Snowball
