I have a 2004 Land Yacht 26ft motorhome. The wipers work, but the intermittent doesn't. Is there a fuse for this, or a module that isn't working. Your help is greatly appreciated. Thanks Rusty
Wiper control unit should be under the dash. That was the cause of my intermittent wiper issue. I guess it could be a ground or the stalk, but module is likely cause. There is a replacement unit which worked on my 250 classic. Search for an earlier post where I am sure I posted the details. It was a Rostra or Dana item from memory. Obv you need to be sure it will work with your coach, but mine was 91, so probably close
