Old 07-12-2002, 03:36 PM   #1
rdm
rdm's Avatar
Question How do you fix the entry step.
The entry step on our 325 worked perfect untill today.
It is vaccum operated and will not retract quickly or extend.
I found a leak in the vac line and repaired it but the step still will not work properly.
Your thoughts are welcomed
Ray
1985 325 Classic Motorhome
rdm is offline   Reply With Quote
Old 07-14-2002, 08:38 PM   #2
Paul Daugherty's Avatar
When I first bought my 82 310 I thought my step did not work right. After spending about three days of turning the key on, starting the engine, stoping the engine, openning the door starting with the door closed and so fourth and trying to replace the switch. I realized that if you start the engine with the door closed it would work. Open the door the step goes out, close the door the step retracts. But only so many times then it won't work untill you put in gear and move. If you start the engine with the door open it won't work at all, you have to turn the engine off and start it with door closed for it to work
Hope that has been some help
Paul....
Paul Daugherty is offline   Reply With Quote
Old 07-14-2002, 09:16 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Too confusing for me...boy, am I glad mine's manual!
Shari
Lower door step TomW Steps 31 01-17-2005 01:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 08:09 AM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 12:07 PM
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
