Old 03-25-2015, 06:02 PM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
How do you add brake fluid to a 1988 345
I can see my master cylinder but getting to it and adding fluid looks almost impossible, is there a simple method?
Mr. D is offline   Reply With Quote
Old 03-26-2015, 01:11 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
No. You can remove the sheet metal or play with a turkey baster and mirror.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-26-2015, 05:46 AM   #3
Mr. D's Avatar
That's what it looked like to me but I was hoping for better news, I guess having the system flushed might be a good idea for more than one reason. Thanks for the info., Mr. D.
Old 03-26-2015, 06:16 AM   #4
1981 31' Excella II
New Market , Alabama
My old van had an access plate in the floor board. If you don't have one maybe you should add one.
Perry
Old 03-26-2015, 06:37 AM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Amazing my AS is 18 yrs younger and has the same problem, when i had problems and checked on the fluid, found a totally unacceptable situation that wouldn't be solved with a simple flush, using a mirror and paper towels had to wipe out the main storage tank. I had many autos and none ever looked like it, turns out recent changes to fluids makes them fail faster, new recommendations are to flush every few years.
Old 03-26-2015, 07:15 PM   #6
Mr. D's Avatar
Thank you all, I can just imagine what the mechanics will have to say when they see my set up? $$$$$, Mr. D.
Old 03-26-2015, 07:55 PM   #7
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
They had a few comments after they replaced mine....
mayco is offline   Reply With Quote
Old 03-27-2015, 09:10 AM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
If it looks like you need fluid but there are no leaks in the system, it might be time to replace the pads and shoes. The volume of fluid equals the amount of friction material that has been used.
If you are handy, you can use a hand operated vacuum pump and do the change yourself. Have an assistant add fluid with a skinny funnel with a section of hose attached as you vacuum it through. Start at the wheel cylinder furthest away, (RR) then LR, Pass Frt, Drv Frt.
Taking it to a shop wont break the bank either.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 03-27-2015, 01:02 PM   #9
Grosspoluter's Avatar
Franklin Park , Illinois
Funnel
Just recently bled the brakes on my 84 345
I removed the engine cover and used one of thoes long 2" funnels you can get at the auto parts store
YA it still was a little messy
Grosspoluter is offline   Reply With Quote
Old 03-27-2015, 05:50 PM   #10
I removed the sheet metal shield and cut it in half. I welded a flange at the joint to connect the two halves together. Now by just removing a few easily accessible bolts I can remove the rear portion of the shield to have easy access to the master cylinder. Makes life easier.
Cheers, Dan
How Do I Add DEF Fluid? weirdstuff Sprinter and B-van Forum 17 05-09-2014 09:20 PM
Brake Fluid Reservoir Barb H. Land Yacht/Legacy Motorhomes 2 08-08-2011 08:03 AM
Can I add hydraulic fluid to jacks? lululand Jacks, Stabilizers, Lifting and Leveling 5 06-08-2011 02:47 PM
Need help on how to access brake fluid reservoire on a 1997 airstrams cutter poloharvey Brakes & Brake Controllers 3 10-11-2010 10:28 PM
Brake Fluid Reservior Bedford Land Yacht/Legacy Motorhomes 3 07-15-2007 03:06 PM
