Old 12-02-2003, 03:13 PM   #15
87MH's Avatar
1978 31' Sovereign
Images: 292
Third Time The Charm
Alan:
Sounds as if you may have a restriction in the line.
Mine does not have the splitter shown in the picture.
Pic is from (I think) Airstream propaganda, but I don't know the year.
My setup is slightly different. My tank is forward of tag axel (gray tank is where the air tank in picture is located).
Neither do I have the splitter in the air line. Mine has separate threaded collars welded to the front of the tank, each dedicated to one air bag/leveler system.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-02-2003, 03:16 PM   #16
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally posted by thenewkid64
..... Using his as an example may be folly ( sorry Peter ...
Smart move .
My bags are 10 1/2" inflated which already is above the 'Norm'. I set them that high because of the aftermarket 80 gal fuel tank I carry.
I believe 8-9" for the 82 and later models is the correct height.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-02-2003, 03:42 PM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
york
any of you motor home guys ever consider putting a converted york airconditioning compressor to work for your compressed air needs? as long as the motor runs you have air.
seems to be really popular with the off road jeep crowd.
and inexpensive too.
i think i can dig up a link if anyone is interested.
john
you call them ferrets, i call them weasels.
Old 12-02-2003, 03:48 PM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yeah something like this
from the web....
http://www.onboardair.com/
john
Old 12-02-2003, 04:00 PM   #19
87MH's Avatar
1978 31' Sovereign
Images: 292
Engine driven compressor
With all the Smog Crap on mine, I have no idea where I'd put it.
You'd think on something as big as a motor home that there would be gobs of room. The opposite is true. Darn near impossible even to see the area between the engine and the radiator.
It would be great if you could get to it.
Dennis
WBCCI # 1113
AirForums #1737
Old 12-02-2003, 07:07 PM   #20
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Here is what mine look like.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-02-2003, 08:11 PM   #21
Airstream Driver
1997 30' Excella
Images: 51
Thanx for the pic, Brett. Same bags as mine.
Just FYI, the arrow points at the nut for adjusting the bag inflation. Comes in handy for leveling the MH from side to side.
AIR #13
Old 12-02-2003, 08:38 PM   #22
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Your FYI just added a to do to my list. The Drivers side sits an inch lower than the passengers side. I figured it was just due to all the tanks being on one side.
Brett G
Old 12-03-2003, 03:53 AM   #23
87MH's Avatar
1978 31' Sovereign
Images: 292
Welded (Daubed) Control Arm
The close ups by Brett and Alan exhibit similar phenomenons as the '87:
Really bad welds in the middle of the link arms.
In addition, mine makes a 90-degree bend at the bottom, and the factory simply bent a threaded portion of the rod to make the connection instead of a proper control spacer.
Poor engineering and fabrication methods by anyone's standard.
Pretty much everything else on the system seems to be quality construction and well thought out. I always thought the funky control arm linkage was the result of some jack-leg mechanic repair.
Wally would be upset.
Dennis
WBCCI # 1113
AirForums #1737
Old 12-03-2003, 05:50 AM   #24
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Re: Welded (Daubed) Control Arm
I thought the same thing. Someone did a poor repair or was using this part as a welding training class I noticed that I am missing one bushing on one of the arms. Any idea where to get one?
Brett G
Old 12-03-2003, 06:09 AM   #25
LOST , Hawaii
Because of the semi custom way they were built there was probably a lot of weight variation at the corners. It would be pretty easy to level it the way they did it- air it up, adjust until it was right, clamp and weld. Not saying it is right, just cheap and quick.
John
74Argosy24MH is offline   Reply With Quote
Old 12-03-2003, 06:27 AM   #26
Airstream Driver
1997 30' Excella
Images: 51
...... I always thought the funky control arm linkage was the result of some jack-leg mechanic repair.
Hear ya, Dennis. Having two of these on my rig, I would spent hours laying under there and staring in awe at those rods.
Brett, those bushing on my linkage were close to failing. You can look for grommets at the parts store or use a slice of a rubber hose. Then use new bolts with locknuts.
AIR #13
Old 12-04-2003, 08:18 AM   #27
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
my bags are not mounted that way...I will get a photo to post later if the weather is ok. My line runs from the tank (small mounted inside the compartment where the hose and a/c connections are), to a valve where two lines then go to the bags.
The bags are mounted either side of the frame towards the center of the bus. The leveling arm is touchng the floor of the coach and then meets the valve where the air lines come together.
When I pulled off the input lines I could feel air coming thru from the portable compressor. When I pulled off the lines coming from the bags they deflated totally. Now after a few days they are still inflated and higher on the bell than I have had them before.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-09-2003, 05:35 PM   #28
josephhh's Avatar
1979 24' Airstream Excella 24
Macon , Georgia
I hope you guys get this all figured out! I don't even know if my 24 footer has air bags or not. Been too busy on the topside. Reckon I'll look tomorrow. Keep up the good work.
Joe
josephhh is offline   Reply With Quote
