Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 12-02-2002, 06:02 PM   #1
Krazykraut
Guest
Profile:
Posts: n/a
Heat while driving?
Ok I have a Heater in the dash, which works great, but comming of one of my trips this week, I noticed the back of my coach was kind of cold. So where do I get heat from back there?
Old 12-02-2002, 06:19 PM   #2
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
Are you running your Aux. Heat??
JP
JPAIRSTREAM is offline   Reply With Quote
Old 12-03-2002, 02:24 AM   #3
Krazykraut
Guest
Profile:
Posts: n/a
Aux heater
I have the gas heater, which I don't think should be running while running down the road? Also have a aux heater in the AC that needs 110 volts to run?
Old 12-03-2002, 07:56 AM   #4
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
My roof air has a heat strip which is mildly adequate for adding some extra heat inside, but of course I have to run the generator.
Old 12-08-2002, 05:31 AM   #5
TRAPEZE
Profile:
My unit has a pull knob on the dash to open a valve connected to the dash heater. This allows the circulation of the hot water from the radiator through the motor home. It heats the hot water tank as well as two fan forced radiator heat units in the rear of the coach. One under the front couch as well as one under the rear bed. I have hot water and heat going down the road, without using LP or the generator.
Airstreams are great!!!
TRAPEZE is offline   Reply With Quote
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 03:10 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 08:40 PM
cockpit heat ALANSD Mechanics Corner - Engines, Transmission & More... 14 07-06-2003 12:31 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 02:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 03:38 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
