Old 11-03-2002, 02:55 PM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mine is like Peter's I wasn't able to find any large gaps. I do want to insulate on the inner wheel well behind the manifold. My generator compartment is insulated, and I have put some foam sheeting under the couch when I had it out for reupholstery.
The GMCCOOP.COM had the customized coach with all the sound proofing insulation. I like the zero clearance stuff, saw that it was developed for NASA originally. Looks like when get a chnace to order some I will try it in the spots I am concerned about.
cockpit heat ALANSD Mechanics Corner - Engines, Transmission & More... 15 04-25-2012 02:28 PM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 03:10 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 08:40 PM
Starter heat problems ALANSD Mechanics Corner - Engines, Transmission & More... 0 02-15-2003 02:51 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 03:38 PM
