Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 09-28-2003, 08:29 AM   #1
Astrodokk's Avatar
Seattle , WA
Header poll
Since my driver's side exhaust manifold is cracked, I will be replacing with something. I have a blank slate. I know many of you have already replaced yours with different brands and designs, including the pipes as well. Since you are experienced veterans now, I ask:
Would you have done it differently? Are any of you NOT happy with your application? Why?
I've read about several brands of headers, so I know many of you have:
stock
factory headers (newer non cracking)
Banks
Gibson
Hedman
Thorley
other lesser name brands
I have dual exhaust with pipes coming out behind rear wheels. These pipes are rusty with tiny holes in them that I will be replacing and actually having both come out at street side in front of rear wheels. Any of these will work depending on funds. So, my desire in this post is to know if any of these were a mistake for someone or if they regretted going with one brand and wished they had gone with another. Thanks.
On Edit: By the way, I was told by the guys who did my Edelbrock that they recommend Thorley stainless steel. They heard that Hedman ceramic tends to peel or crack off with heat due to thermal expansion and contraction from 2 different types of metal. I know though that Hedman makes different types or styles too. Most of these are California smog legal.
Astrodokk is offline   Reply With Quote
Old 09-28-2003, 09:08 AM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
When I first got my MH, I had to replace the mufflers and the tail pipes (they were in bad shape). A few month later the drivers side manifold started leaking. I replaced it with a stock OEM GM manifold. Another two month later the passenger side started leaking and upon inspection was warped badly. So I replaced it with the OEM as well.
If I would have known what was to unfold, I would have gone with the banks system.
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 09-28-2003, 11:30 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I have heard many good things from users of Thorley headers. on their 454 chevys.
I also crave the Banks system, but it is quite pricey.
Old 09-28-2003, 01:36 PM   #4
zduke4x's Avatar
Thumbs up Banks system
I have a Banks system that is a vast improvement with stainless headers and 3" tailpipes with heatshields and a lifetime warranty.
I have also read here on the forum that Banks recommends Gibson(also stainless and 3") if they aren't able to fit your rig.
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 09-28-2003, 04:07 PM   #5
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
454 and headers
Hi Astrodokk,
There are many systems out there that are designed to 'improve' the breathing of the BB chevy. Doug Thorley makes headers designed to improve the torque of the BB Chevy and that is what we towing fools need, more torque.
I have Thorley headers on my 454. They are chrome plated not stainless; recently Thorley, I believe, has released their headers with a ceramic coating (probably the best of both worlds). The Thorley route is probably the most cost effective for improved torque and improved gas milage (some, not much).
Once the headers are on you must plan the exaust system out to the atmosphere. Dual 2.5" pipes with a crossover would probably be the best. Choice of muffler is up to you. Quiet is good for me.
Have you done anything to the other end of the power equation i.e. any intake improvements? The addition of headers, regardless of type (other than stock replacement), causes a change in the gas flow. If there is not a similar change to the intake side of the engine, far less than the full benefit of the headers will be realized.
Just food for thought!
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 09-28-2003, 05:18 PM   #6
Astrodokk's Avatar
Seattle , WA
Yes, I just had an Edelbrock Quadrajet 1906 spread bore electric choke replace the old Rochester so that it could pass smog in CA.
What is BB?
Old 09-28-2003, 06:12 PM   #7
RichardT's Avatar
[i]
What is BB? [/B]
BB = BIG Block
RichardT is offline   Reply With Quote
Old 09-28-2003, 06:13 PM   #8
dinoburb's Avatar
1982 34' Limited
BB
Sorry,
As you might know Jargon is simply a way for those in the know to keep out those which are less fortunate!!!
BB means Big Block Chevrolet (454 et al)
By the way did you change the intake manifold or are you using the original cast iron manifold? The carb you mention is the stock Q'jet replacement carb, a good choice, but not an improvement in terms of air/fuel flow. An aluminum dual plane Edelbrock Performer manifold might just be the ticket to pull it all together.
Take care,
AIR 1446
W5CDR
'78 Honda GL-1000
Old 09-28-2003, 07:42 PM   #9
Astrodokk's Avatar
Seattle , WA
It's the original. They didn't even give me the option of changing out the intake manifold when they replaced the carb.
Would the intake manifold you mention work with the new carb? Also, does it help with gas mileage?
Old 09-28-2003, 08:07 PM   #10
dinoburb's Avatar
1982 34' Limited
New Performer Manifold
Yes, the Performer manifold for the 454 with the original Spreadbore Q'jet and the Thorley Headers would make an improvement in the milage. The manifold can be purchased for engines equiped with Exaust Gas Recirculation (EGR) or without. Emissions legal to boot!
However, remember this is a 454 which at 11.5mpg is doing outstanding. You can't expect 15mpg from this rig, but you can expect it to run quite a long time if properly cared for.
AIR 1446
W5CDR
'78 Honda GL-1000
Old 09-30-2003, 02:59 PM   #11
LOST , Hawaii
Before you change manifolds check clearance to the doghouse. I put a Holley dual plane manifold and Holley TBI on and had to raise the cover 2".
John
74Argosy24MH is offline   Reply With Quote
Old 09-30-2003, 05:29 PM   #12
dinoburb's Avatar
1982 34' Limited
Good Point!
One of the reasons I suggested the Performer manifold is that it is a low rise manifold similar to the original cast iron one from Chevrolet. The flow characteristics are better though!
It never hurts to check heights before commiting to any major engine change. Do not use the Performer RPM as that is a high rise dual plane which probably would not clear.
AIR 1446
W5CDR
'78 Honda GL-1000
Old 09-30-2003, 07:31 PM   #13
Astrodokk's Avatar
Seattle , WA
Well, due to limited funds, I decided to go with Thorleys, which are $370. at Summit. The intake manifold will have to wait too, unfortunately.
I've been advised to get the pipes crossed over, but will that work if i have both tips coming out the street side front of rear wheels? I know Peter has his exiting that way...are they crossover?
Old 09-30-2003, 07:43 PM   #14
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
A crossover is normally installed just rear of the engine to help balance the flow. The routing of the final exit to the roadside will not be effected by the crossover. Before you buy the crossover I would talk to the shop that is doing the install. They may be able to do it for you for less.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-01-2003, 04:22 PM   #15
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you do go with the headers, you may want to look into rejetting the carb; headers flow more air and I've heard they tend to make the engine run a little leaner....
-Don
Poll: Isuzu Diesel MH - Would you do it again? ViewRVs Mechanics Corner - Engines, Transmission & More... 4 08-14-2013 01:51 PM
Make of your tow vehicle John Community Polls 97 11-24-2011 02:24 PM
POLL: Axle Replacement Safari Tim Axles 45 01-30-2006 09:02 PM
'66 - '67 - '68 window poll Forrest Windows & Screens 7 11-24-2003 08:27 AM
camping or sight seeing....POLL! Safari Tim Our Community 9 07-08-2003 03:05 PM
