Old 04-23-2015, 07:28 AM   #1
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Question Hardwood in Classic 345
Dear all,
now our beauty is finaly on the road with German registration, we passed the TÜV control !!!!
I begin now to "make up" her inside, we have torn out the old, dusty carpets and we wish to install a hardwood / laminated floor instead of new carpet, due to hygienic issues.
Who has done this Before?
What can i install between the Airstream floor (plywood/OSB) and the laminated new planks, to avoid the noise of a "rolling drum" by travelling or walking inside?
I am also concearned anout "cold feet", because we use to camp in her in wintertime.
Do we need any special treatment / coating, beforte we cover the underfloor with some new planks?
I am a woodworker, i know, how to install properly the new woodflooring, but we have no expirience with woodfloor in Motorhomes
Roquefort is offline   Reply With Quote
Old 04-25-2015, 06:28 AM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
If you look in the "classics" section, there is a thread titled "what did you get for you motorhome today?" Post 1194 on that thread has info from my flooring job last summer. I used no underlayment between the plywood and the flooring, no squeaking or noticeable change in road noise. It Is slippery and chillier on the feet than carpet, but infinitely cleaner.
Waipio Rim is offline   Reply With Quote
Old 04-26-2015, 07:11 PM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Use cork instead of wood. Cork insulate is easy on the feet and soft of you drop something. You can finish cork like wood or I know in Germany the have pre finished tiles.
PSchw is offline   Reply With Quote
Old 04-26-2015, 07:33 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A cabinetmaker myself, I have an engineered hardwood floor in my 310.
An engineered flooring is very stabile in comparison to a true hardwood floor, thusly alleviating the problems with shrinkage, cupping and expansion. An engineered floor also weighs less, is easier to install, more importantly remove if needed and is cheaper. I would imagine that there are some really good engineered products in Germany.
The Torly's product I used also had a soundproofing underlay that I used under the engineered floor but also underneath the front cockpit area carpeting as well. Look at underlay in the link below.
http://www.torlys.com/residential/products/accessories/
IMHO I would avoid a true hardwood as the temperature and humidity variations in a RV make for a nasty mess if not done correctly. Also I used a carpet in the cockpit area as doing hardwood up around the doghouse is not only a pain, figuratively and literally, but carpet has give and is softer for driving long distances.
Cork makes for an excellent floor and would be a hell a va lot warmer than the flooring I have.
Cheers
Tony
Old 04-28-2015, 01:24 AM   #5
2000 36' Land Yacht XC Diesel
Fresno , California
I'm thinking about having engineered hardwood installed in my XC diesel. I have it thought out my home and I usually advise my clients to do the same. I live in California where most homes are built on cement slab foundations and real hardwood cannot be installed on cement without putting a plywood layer down first which then raises your floor a good 2".
I completely hadn't thought about cork for my motor home but I LOVE a cork floor. They're so comfortable and will totally flex with the movement of the RV. So glad I read this post as I think that's the direction I'll be perusing. Just know cork is very expensive right now due to its endangerment.
LucasS is offline   Reply With Quote
New hardwood floors- finishing touches kween Floor Finishes 11 03-25-2013 08:31 PM
hardwood subfloor mig Repairing/Replacing Floor &/or Frame 5 08-30-2008 02:07 PM
Hardwood in Bath rc707 Floor Finishes 11 06-16-2008 11:55 AM
New Hardwood Floors 87 34' Excella tslanier Repairing/Replacing Floor &/or Frame 1 10-12-2006 08:11 PM
Hardwood Concern J&C Floor Finishes 24 04-03-2004 02:54 PM
