Old 03-07-2004, 06:46 AM   #1
Gray water tank removal
Any tips on removing the grey water holding tank? I have a severe leak when it gets to the 3/4 full point.
I have a 1988 345 with center bath. The book makes it sound simple.
AccessMaster is offline   Reply With Quote
Old 03-07-2004, 10:05 AM   #2
I found the problem. The tank is cracked at the tank support bracket. I still do not see any way to disconnect the drain hose from the interior from the tank. I can not see where it enters the coach to try to disconnect it from the inside. The clamp is not visible from the tank side.
Is there a technical support line to Airstream I can try?
Looks like I will need a new tank. Any suggestions?
