Old 07-06-2015, 10:12 AM   #1
2015 Interstate Ext. Coach
Tulsa , Oklahoma
Gray water gauge on new sprinter
I pump black water and gauge goes to empty. This is the second time I've pumped. Gray waster gauge shows 2/3 even after pumping. It looked like it was pumping, but I had discharge screwed onto sewer inlet in KOA. I go out and unscrew it and watch pumping. Only small spurts left so I would think tank is empty.
Thoughts?
Bobsprinter is offline   Reply With Quote
Old 07-06-2015, 11:13 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The gray tank could be full of soap suds, but still empty of liquid. Try this test, just for giggles… When you've pumped the gray tank empty and it still shows 1/3 or 2/3 full on the so-called gauge, fill it again, one gallon at a time using a one-gallon bucket filled from the shower nozzle, and emptied down the shower drain. See how many gallons it takes, and compare that to what the owner's manual says your gray tank capacity is.
What this little test will do is show you that the pump really does pump the tank empty, and show you that the tank gauge lies like a politician in an election year.
Cats and ultraleather Airstream upholstery don't mix!
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
Shower water and the Gray Water Tank MIKO92 All Argosy Trailers 16 07-22-2014 12:53 AM
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
