Old 10-22-2017, 09:09 PM   #1
alhamilton's Avatar
1975 Argosy 26
1975 26' Argosy 26
Placerville , California
Gear Vendor and steer safe
This past week the gear vendor over drive and a Steer Safe device were installed. Both work great. The gear vendor shifts effortlessly and drops the RPM a bunch. Week after next we will take her for a drive and check mileage.
Also the Steer Safe keeps the steering centered and will return to center hands off.
Oh yes we have a 75 Argosy 26' with 454 on the Chev P30 chassis.
Next job will be to eliminate a bunch of extra wiring that others have installed some of which work and some doesn't. The dash oil and amp gauges don't work so some one hung those extra gauges under the dash. I'll fix the originals if possible. Anyone have advice?
al
alhamilton is offline   Reply With Quote
Old 10-23-2017, 12:47 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
al
Did you have an original steering damper? Most 1974/75 models I have seen don't unless retro fitted (like Bella).
The ordinal gauges are all still available new from Mill Supply.
martin300662 is offline   Reply With Quote
Old 10-24-2017, 12:30 PM   #3
alhamilton's Avatar
1975 Argosy 26
1975 26' Argosy 26
Thanks Martin.
Old 10-24-2017, 04:53 PM   #4
alhamilton's Avatar
1975 Argosy 26
1975 26' Argosy 26
No original steering damper. I'll check Mill Supply. Thanks Martin.
al
Steer safe steering stabilizer davejay Airstream Motorhome Forums 1 08-26-2017 10:32 AM
Steer Safe question porourke Land Yacht/Legacy Motorhomes 5 03-16-2012 12:50 PM
Power steering pump failed after steer safe installation. LandYacht33 Mechanics Corner - Engines, Transmission & More... 4 10-09-2011 07:56 PM
steer safe str8strm Classic Motorhomes 8 06-12-2006 05:40 PM
