Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 01-31-2016, 09:40 PM   #21
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
you need a catalytic heater as backup
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 01-31-2016, 10:12 PM   #22
Originally Posted by PammieSue View Post
What he said.
Chris and I are buying one of these from my daughter.
http://www.amazon.com/Mr-Heater-F232...+space+heaters
They have this heater on clearance at Walmart for $30, check your local stores
0557 is offline   Reply With Quote
Old 02-01-2016, 01:54 PM   #23
coairstream's Avatar
1988 34.5' Airstream 345
Denver , Colorado
I'll look into that for sure!
Now that I'm back in Colorado, have become more familiar with her, and had her winterized I've had time to think about it. Having additional item(s) on board when I already have redundant systems doesn't seem necessary. Tell me if I'm missing something and these are my thoughts:
1. I bought new batteries so that fixed my problem.
2. My bearings in the motor were squealing, especially on start up. I replaced the motor, and now feel confident in the furnace working good.
3. If I'm plugged in I don't need to be worried about draining the house batteries and a 12 volt ceramic seems to be a good back up even if boondocking. I know it draws on the battery but I can fire up the onboard generator. If its after generator hours and my batteries are low the Mr. buddy catalytic heater would be nice to have.
4. One of my roof units is a Coleman Delta T and it seems to have a heat option. I haven't tried it yet and this would also only work if plugged in or have the generator running.
After typing this out I think I it comes down to if I want to have a true back up the catalytic heater is the way to go. I don't do much cold weather camping but it would of been nice to have a back up on this last trip!
Do most of you just travel with a few small bottles stowed away or do you have a location you can tap into the propane from the inside?
Cody
coairstream is offline   Reply With Quote
Old 02-01-2016, 02:36 PM   #24
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
We just got back from a two week stay out in CO when they were having night time temps of 0-5 degrees and highs in the low 20s during the day. We were nice and toasty in our 310 but we wouldnt consider doing it without electric hookups where ever we stayed. The blower motor on the furnace is going to eat up your battery power and its going to be a struggle dealing with that if boondocking. Most folks questioned our sanity to do the trip WITH electric hookups. We use 2 electric ceramic heaters and the furnace to keep the rig warm. The two ceramics do a good job and the furnace didnt run a great deal. Im not saying it cant be done but I know we wouldnt attempt staying in the rig in those temps without electric hookups. For us, I would be too concerned about keeping my batteries up and heat going to have any fun... Plus, if something does go array, and youve got water in your system, then things could get messy real quick. Just my thoughts.....have fun...stay warm.
One more thing, make sure your converter is charging correctly. I know you put new batteries in and the furnace started working well. But, if the new batteries were fully charged when you installed them then you MAY have been running them down and the presumed "fix" is temporary. Just double check your charging system with a meter. Check it at your batteries with the rig plugged into shore power and then check again with just the generator running. Your converter should be putting out around 13.5v I believe. I would check it just to make sure so you dont head out again and find the new batteries arent getting the correct charge.
Mike
mayco is offline   Reply With Quote
Old 02-01-2016, 03:16 PM   #25
Wise Elder
Jammer's Avatar
2010 30' Classic
Hello coairstream
Glad you figured it out.
Winter camping is a topic in its own right, and there's a subforum on that here where there has been extensive discussion of winter camping and winter boondocking.
With everything working properly it should be possible to run the furnace for a night or two if you start with fully charged batteries.
Adding another battery can add another night or so. Conservation measures can play a role.
As others have pointed out, winter camping will make full use of your electrical system and any problems or inherent shortcomings of that system will become obvious.
There are many strategies for carrying/obtaining sufficient propane for longer stays where electricity is available or a generator is being used
You can charge the batteries quickly from the generator if the converter is a modern temperature compensated 3 stage one.
I do not believe catalytic heaters are safe for reasons I have written about many times in the past. There are better alternatives. Search is your friend or if you want more details PM me
Old 08-26-2016, 08:14 PM   #26
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey jammer,
This is off the furnace subject. How did you come by the name jammer. I ask because in glacier park, the people who drive the red busses are referred to as jammers. Also truck drivers back in the day were called gear jammers. Now we got automatics. I hate them. I'll take a 15 speed any day manual, of course. I ask because back in 85 I worked in glacier park. Knew a few of the jammers. Met a girl there too. 31 years now together. Thanks dave
davejay is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heater blowing but no heat? LilyAnder Sprinter and B-van Forum 3 11-09-2015 08:25 AM
Furnace lit, but no heat L911 LP Gas, Piping, Tanks & Regulators 27 09-26-2012 05:57 PM
Furnace on 72 Tradewind pilot lights but no heat RichHog Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2009 02:33 PM
Furnaces blowing but no heat Dave Emmerich General Motorhome Topics 6 01-04-2003 07:53 AM
