We have a l987 Airstream 345, and ocassionally, when we want to run both furnaces at the same time, the bedroom furnace does not always (100% of time come on, If we only turn on the Bedroom without the galley furnace, we always get heat. We were concerned about this. We visited the factory this month, and they took a look at it. They concluded that we needed to replace the gas regulator. You might consider this. It is significant that the bedroom furnace fan etc., runs when we push the thermostat up, but doesn;t always ignite and put out heat. When we turn off the galley furnace, then the bedroom furnace always works OK
Dr Joe & Winn
Emeritus Airstreamers
KD8VD
