Old 02-19-2015, 06:55 AM   #1
Hernando , Mississippi
Unhappy Front furnace not working
The fellow that I purchased the Moho from says the front furnace relay/circuit breaker was bad & he had ordered it and would send it to me. Still nothing from him. Does anyone know where the relay is located ? He showed me the relay and it looks like an automotive type with 2 blades that just slides in like any automotive type. It's really cold here in Mississippi so I would like to get it fixed asap. Any info would be greatly appreciated. Thanks
Highcountry is offline   Reply With Quote
Old 02-19-2015, 08:18 PM   #2
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
Not here, but would be interested to know as I have developed the same problem with my rear furnace.... right about the time I mentioned both worked with no issues.... darned airstream gods... decided to smote me for my arrogance and profaning against them for the coach's reliability.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 02-20-2015, 05:37 AM   #3
1995 36' Classic 36
Ludington , Michigan
The only circuitry for the furnace that I know of is the main control board. Open the outside cover and its sitting right there on the left. It contains the igniter, gas valve, motor control and timing functions. PPL has them and they run about $100. You will also get an updated version which is coated for better weather protection. I swapped the boards from the front to rear furnace to verify it was the problem. The front one had already been replaced with the updated version. It also a favorite place for mud dobbers. They built a nest over my flame detector and igniter. I believe the high voltage smacked the flame detector. It's a pretty easy job to get at it and swap it out.
Verify the part number before ordering but I believe this is the one I used.
http://www.pplmotorhomes.com/parts/c...MqJBoCmxfw_wcB
Kota is offline   Reply With Quote
Old 02-20-2015, 09:07 PM   #4
Vycan's Avatar
Thanks Kota
Old 02-21-2015, 05:02 AM   #5
1995 36' Classic 36
There is also a DC voltage threshold below which they won't run. The old controller wouldn't work below about 11 volts.
Old 02-21-2015, 12:42 PM   #6
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Wasp problem
You could get a wasp screen from most any rv dealer to solve that type of a problem with bugs.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 02-21-2015, 01:38 PM   #7
1995 36' Classic 36
Yup! Did that after I learned.
Furnace Not Working - Troubleshooting Help Please RonaldC303 LP Gas, Piping, Tanks & Regulators 9 11-29-2017 07:47 AM
Water heater and furnace not working ILOVESALLY Full-Timing 14 02-08-2015 07:19 PM
Furnace not working Hounddog General Repair Forum 0 08-16-2012 08:29 PM
Furnace not working after several problem solving attempts Rikh Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-24-2010 03:58 PM
HELP - my furnace is not working Mightymite Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-27-2010 01:33 PM
