Old 12-05-2017, 10:15 PM   #1
1987 34.5' Airstream 345
northern IL , Illinois
Front Coil Springs on 345
Hello
I'm working on my MO and see that one of the front air bags is not holding air.
Is anyone just running new coil springs with more spring weight rating.
And no front air bags.
I found this from a old post.
In the video Vintage Airstream Classic Motorhome Factory
At 6:59 in the Video you can see the front of the MO is way up in the air.
Unlike what I see on my MO. I know it's got miles and 30 years on it.
Can I get my MO back up in the air.
I don't think the front air bags gives lift just holding the ride height when it gets filled with people and gear.
Has anyone gone down this path with new coils and no air bags.
And what coils did you get. Weight rate.
Thanks Hans
Hans 34.5 is offline   Reply With Quote
Old 12-06-2017, 01:47 AM   #2
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Check the fittings and hoses before you blame the air bags.
Replacing the air bags is a pain but cheaper and easier than the springs.
If you think your springs are soft and will replace them, put in new air bags too.
They do not add much to the height, but they do dampen a bumpy ride.
WayneG is offline   Reply With Quote
Old 12-06-2017, 08:02 AM   #3
Original Coils spring and no hose on the air bags just the air valve.
I have to measure the front control arms to see what the height is.
What coil spring do I use. Not into the low ride.
Looking up Coil springs for replacement has a lot of options.
I'm ok with putting new air bags in to help with the ride.
Old 12-06-2017, 09:49 AM   #4
1969 31' Sovereign
1982 28' Airstream 280
Edmonton , Alberta
Supersteer has good quality replacement parts for our p30 chassis's.
From what I have read the chevy plant used generic springs regarding weight so one size fits all approach is very flawed.
When I get the money to do my front end I will be using their products.
Swillv8 is offline   Reply With Quote
Old 12-06-2017, 10:59 AM   #5
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Both of ours (310 and 345) came to us with no front air bags. Sorry I can't tell you where the heavier springs came from, but both have some other Supersteer parts on the front end.
Waipio Rim is offline   Reply With Quote
Old 12-06-2017, 11:09 AM   #6
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Itís all there on the site. Supersteer coils or new bags with tubing and valve
Iíve fitted the front bags. You knacker you hands but itís just fiddly. Google the site and youíll find instructions and tips.
Boom Sounds is offline   Reply With Quote
Old 12-06-2017, 09:54 PM   #7
Thank you all for your help.
I think the #6560 coil spring will be the one to use with out the air bag.
#6560S is if you have some extra weight on the front bumper cow catcher big winch.
And you can use the air bags if you like.
All the front coils will get the front up to the right ride height.
Measuring the gap from the bump stop up should be 1 3/4 to 2 1/2 inches.
This is on the lower control arm.
Old 12-11-2017, 04:58 PM   #8
2004 26' Land Yacht Gas 26
Thibodaux , Louisiana
Have the supersteer coils on my 2004 26 ly, with no airbags. I like them.
latenite23 is offline   Reply With Quote
Front coil springs shepherd57 Classic Motorhomes 12 05-18-2017 09:09 AM
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
SuperSteer Coil Springs - 96 front axle weight pago cruiser Land Yacht/Legacy Motorhomes 11 08-07-2016 05:31 PM
345 front coil over shocks . . . Help Ice Berg Classic Motorhomes 49 06-05-2014 10:52 AM
Air Bags In the front coil springs spat61 Land Yacht/Legacy Motorhomes 5 10-25-2007 07:10 PM
