Old 05-03-2003, 05:26 PM   #1
Front Air Shocks blown
Both of the bags are blown on the Classic 345 front shocks or springs. I do not know how much diffence it would make to have them replaced. It rides pretty nice now. I am looking for opinions regarding my options.
AccessMaster is offline   Reply With Quote
Old 05-03-2003, 08:47 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
The front end alignment was done with the air bags at 55 psi.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-04-2003, 07:18 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You will find they are not too hard to replace, and not very expensive either. There are numerous sites with some do it yourself info on this. Search within this site also and you will find some.
Most wrap the uninflated bag, lube it with soapy water and stuff it in where it goes. If it is manually inflated no compressor is required, unless you want that option.
The ride is way better with the right air pressure.
Old 05-09-2003, 10:06 AM   #4
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Re: You will find they are not too hard to replace
Alan,
Have you replaced yours? It is easy in a technical sense but a bear to remove and re-install. Maybe there is some secret that I missed. I tried the Air lift instructions by squishing them and using soapy water. There still must be an easier way. My shoulders were sore for three days.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-10-2003, 09:41 AM   #5
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
dont take much to make us ole guys sore. there isnt an easy way
just brute force. lol
al
wb13798 is offline   Reply With Quote
Old 05-10-2003, 01:11 PM   #6
ViewRVs's Avatar
1977 20' Argosy 20
I drove mine today for the first time and it did drive much better. I am glad I replaced them. A definite improvement on a rough road.
Fred H.
Old 05-10-2003, 01:50 PM   #7
So where is a good source for the air bags?
Old 05-10-2003, 02:43 PM   #8
Any Airstream dealer, if their interested in helping you.
inlandrv.com
Old 05-10-2003, 03:10 PM   #9
wb13798's Avatar
2004 28' Classic
camping world and they install...lol
al
Old 05-10-2003, 03:10 PM   #10
ViewRVs's Avatar
1977 20' Argosy 20
I bought the Air Lift bags from Camping World. $60 and some change. Installation is another $60 and change if you want.
Fred H.
Old 05-10-2003, 07:53 PM   #11
Thumbs up installing air bags
I found it helpful to pull a vacuum on the bags prior to installing them( I used my ac vacuum pump) it made them easier to put up into that little small hole.It also helps to twist them like wringing a rag out but it still makes your hands sore.
George is offline   Reply With Quote
Old 05-11-2003, 11:06 AM   #12
Fred.
$60.00 each or for a pair?
You didn't say.
inlandrv.com
Old 05-11-2003, 04:11 PM   #13
ViewRVs's Avatar
1977 20' Argosy 20
Camping World has the Air Lift 1000 replacement bags for $62.99 (member price). It is a pair. Item # 4961
The catalog lists installation at $69.00.
Fred H.
Old 12-28-2003, 08:07 PM   #14
I finally installed the front airbags this weekend.
What a job but what an improvement in the ride.
I wish I had a vacuum pump to squish those fellows flat. Seems like there must be a trick to getting the bag small enough to get thru the 2" hole.
I did not realize how much bouncing around I was doing without them.
Any comments on the correct pressure to run?
Shocks or no shocks? Thisisliving Shocks 34 07-01-2013 08:59 PM
'87 MH Front end air shocks ericjan2 Repairing/Replacing Floor &/or Frame 2 09-27-2012 11:02 AM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
