Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 03-12-2002, 06:42 PM   #1
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Fred vs. Hose Reel
I called an RV repairman about my hose reel and the guy wanted to charge 4 hours at $50/hour plus $35 just for coming to look at it. That's $235! What a joke.
I have decided to puchase a Dremel tool on Friday and carve/cut a bigger hole in the reel hub. This way I avoid taking out the hose reel and solve my long term problem at the same time. Dremel makes a right angle adapter that will make working in the tight space easier.
I will not be defeated! More to come......
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 03-12-2002, 07:30 PM   #2
PeterH-79MH's Avatar
Profile:
Images: 63
Fred:0
Hose reel:1
PeterH-79MH is offline   Reply With Quote
Old 03-13-2002, 05:41 AM   #3
1985air345's Avatar
I know that seems like I am avoiding taking it apart and putting it back together properly. The bigger issue is the need to easily access the hose fitting. Should I have to take apart the whole thing every time I want to change the hose?
I am only going to cut away a large enough section to access the hose fitting. If I cut too large a hole, I do risk effecting the structural integrity of the reel.
Yes, the reel gets a point for fighting back my attempt at getting it off but this is a long game! Besides, I can't use my MH until this gets fixed. If I turn on my pump, water shoots out the hose fitting. I normally have a cap on the hose to hold the water in.
Fred H.
Old 03-13-2002, 06:44 AM   #4
Profile:
Images: 63
I believe, there should be a check valve on the hose side of the waterpump. (besides the pressure regulator). You should not have to cap your hose.
Old 03-13-2002, 03:13 PM   #5
1985air345's Avatar
'should be' being the operative words. I think the check valve is there but broken. The pump and hoses look like a bowl of spaghetti. I had Walt's RV take a look and he just capped the hose. The hoses go everywhere and there are a dozen knobs in there. The person who did this did not love the coach like we do (oh, this from the guy getting ready to cut up his hose reel instead of doing the right thing by taking it apart!!!!!!)
One of these days I'll trace the hoses and label them. Right now it's my dirty little secret under the bed. That WON'T be part of the tour in April!!!!!!!
Fred H.
Old 03-13-2002, 08:03 PM   #6
Profile:
Images: 63
Spaghetti
My bowl of spaghetti also had a build-in sprinkler system.
Instead of messing around, I just redid it all. Now I know each and every line by first name.
The picture shows it about 80% complete.
Old 03-25-2002, 05:38 AM   #7
Profile:
Images: 63
Fred:0 Hose reel:1
ROUND 2
Old 03-25-2002, 05:17 PM   #8
1985air345's Avatar
Fred 2, Hose Reel 1
The Dremel tool worked great. I did break a good 10 of the bits for metal. I cut two 1"x1" sections out. Just enough to put the new hose on. The new hose is on and is not leaking.
I painted the battery tray with Rust-o-leum Aluminum color paint. After that dried, I put the batteries in.
I sanded down the left outside drawer and painted it with primer. Some bright individual put a carpet welcome mat in there that soaked up water and rusted the drawer.
A very productive day!
Fred H.
Old 03-26-2002, 09:07 AM   #9
1985air345's Avatar
Here's my dirty little secret. Since I know more now than I did 6 months ago when I took the photo, I need to figure out where these pipes go.
Fred H.
Old 03-26-2002, 10:16 AM   #10
GA Airstreamer Air_005
Profile:  North , Georgia
Fred -2 Hose Reel -1 Winner "Fred" by a nozzel.
How about that water filter? I changed mine(same type) and it was amazingly nasty inside. The reason I carry bottled water for drinking, and keep the tank water for washing. As easy as the filters are to clean , I plan on cleaning mine more often.
If you get a raincoat on and want to check where those lines go, you could disconnect/plug them one at a time and see where the water comes out, then write on the hose with a magic marker.
Mine are easy to trace, under the sink in the kitchen.
Old 09-01-2007, 07:34 PM   #11
jagcb750's Avatar
Profile:  Barbourville , Kentucky
I just did this mod on my 345. It worked like a charm. However, there was a little leak inside the reel. I thought I was in for a long haul, but when I came back later the leak had stopped. I figure there must be an o-ring or something inside of it or something that was leaking and just stopped. go figure?
JaG
My "new" 1986 345: "Ol Nancy"
jagcb750 is offline   Reply With Quote
Pingbacks are On
Sewer Hose Questions (peww) overlander76 Waste Systems, Tanks & Totes 28 06-09-2007 10:01 PM
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 06:16 PM
1986 345 MH H2O Reel Jim Tyrney Airstream Motorhome Forums 2 10-21-2003 09:22 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 08:25 PM
Automatic electric cord reel cameomike Batteries, Univolts, Converters & Inverters 5 09-02-2002 12:04 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
