The solution to your problem is under the front swing down panel in front of the MH. There are three automotive type circuit breakers, about eye level just left of the battery isolator. They are small, silver, with wires attached to them. I had this same problem and these breakers were the cause. Also check the wire connectors, sometimes these become loose
