Old 04-30-2003, 03:48 PM   #1
exterior work at front end
The front gille, trim etc on my 85 345 looks a little road worn. I only have approx 50,000 miles on it. Has anyone polished the girll, replaced the vinyl trim stripe etc? Also does anyone have the paint color # for the dark gray at the bottom of the coach?
mlmarch is offline   Reply With Quote
Old 04-30-2003, 04:14 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
paint color
Dupond B 8270
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-03-2003, 06:10 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I have polished the grill bars using extra fine steel wool and "mothers" mag and aluminum polish. It worked ok to clean it up, but will not retain the shine very long without sealing it. The grill takes a lot of abuse! Does look better though. I also did the bumpers.
I also restriped, but I changed the colors, on my rig they are not as extensive as yours, the stripe is mainly midline. Check the photo here;
http://www.airstreamphotos.com/photo...papass=&sort=1
Old 05-03-2003, 04:46 PM   #4
vinyl strip
Alansd
I looked at your photos of your new vinyl stripe. It looks good. I also saw your new chair covers. They also looked great. The couch also was redone. Did you do this yourself? How does the couch come out? Etc. On the grille-did you recoat with anything?
Old 05-04-2003, 07:25 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
the couch on my model is really a box, with the fron pads screwed on, and the top seat/bed bolted down on the sides. It is easy to take apart, however I had it professionally recovered.
I did not want to attempt the stiching and cutting of new upholstery fabrics, and left that to a pro. He also did my captains chairs, barrel chairs, wall trim and fron ceiling padded trim.
Wile the couch was apart I cleaned out the area around
the water tank, and rewired my stereo and door bell. Both had parts under the couch.
I have not yet sealed my bumpers or grill, I used polish on them and repainted the black grill bars. They take a bit of elbow grease to keep looking shiny.
front end alignment wb13798 Mechanics Corner - Engines, Transmission & More... 2 12-11-2003 12:11 PM
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 10:13 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
