Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 10-17-2003, 09:24 PM   #1
Astrodokk's Avatar
Profile:  Santa Rosa , California
Exhaust pipes to exit left but where?
As the work is coming along, I was asked by the exhaust guys what those lines are where they are intending to exit the dual exhaust tips. I said it is the water heater up above them so they said good it's just water, but now I'm wondering if it's the propane lines. Anyone know? I know Peter has his coming out the leftside driver side street side, whatever label it gets. This area that I'm talking about is right in front of the rear wheels. Thanks.
Astrodokk is offline   Reply With Quote
Old 10-17-2003, 09:49 PM   #2
Profile:  LOST , Hawaii
The water lines are all inside. Copper line with a T running up through the floor? Follow it and more T's, it is propane.
John
74Argosy24MH is offline   Reply With Quote
Old 10-17-2003, 11:28 PM   #3
Astrodokk's Avatar
Propane it is.
Does it create a potential problem with the exhuast pipes coming close to those propane lines as they exit out the left? I'm talking explosive problems. I know that propane won't explode as gasoline does, and after all, it ignites for water heating and fridge and generator with no probs. How unsafe can it be with the pipes coming out there?
Old 10-18-2003, 07:44 AM   #4
How far from the engine will they meet? How close will the exhaust be to the propane line? Will the propane line be in a pinch point?
The exhaust cools quite a bit as it goes through the pipe. I am guessing that it has to be 8 or 10 ft. so heat shouldn't be that much of a problem. I would think about when the exhaust starts to fail. Don't let them install it so that when the pipe rusts through it will rise up and rub or pinch the propane line. A strategically placed hanger or two will prevent that.
John
Old 10-18-2003, 07:51 AM   #5
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
An additional option is to fabricate a heat shield over the last 12 inches of the pipe so there is less chance of the hot exaust pipe coming in contact with the propane line.
I agree with John that the exaust gas temp should be low enough to not be a concern, the actual pipe is a different story.
Brett G
WBCCI #5501 AIR # 49
Old 10-18-2003, 08:25 AM   #6
PeterH-79MH's Avatar
Profile:
Images: 63
Yes, those are gas lines. Just make sure they don't stack the pipes on top of each other.
Side by side and a few inches of clearance.
It also serves as an incentive to check your lines and drive without the gas on.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 10-18-2003, 09:21 AM   #7
Astrodokk's Avatar
Drive w/o the gas on!?
I usually drive such that the gas is always on, so that I can turn on the fridge at a push of a button, or even the hot water heater, which has the optional on switch at the control panel. Also the central heater and the generator can be turned on while driving, since they are propane.
I read somewhere that if one turns the main gas off, it's a bear to bleed the lines and relight things.
The pipes will be horizontal to each other, and a heat shield sounds like a good idea. I wonder how much they'll take me for that. I think they may throw it in if i ask nice. After all, they seem to be really enjoying working on this rig. They act as if it's theirs. They even told me that if I get a property with land to park it, I may never stop tinkering with her. I wonder what they mean?
The exhaust manifolds are off! Now what? swebster Mechanics Corner - Engines, Transmission & More... 13 08-07-2005 01:29 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-27-2004 12:42 AM
exhaust sys. for 85 345 Lido&Linda Airstream Motorhome Forums 9 02-05-2004 10:30 PM
Where do these water pipes go? letsgo Fresh Water Systems 1 12-21-2003 08:56 PM
Furnace Exhaust niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-27-2002 10:19 AM
