Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 01-01-2004, 11:05 AM   #1
howardann
Profile:
Question exhaust 345 classic
Our 1988 345 classic with the 454 still has the original exhaust system.it's looking pretty bad.should I replace with OE parts from GM or go to a custom bending place? any suggestions on mufflers? Also my AES Dometic fridge is not working........repair or replace.Thanks Howard
howardann is offline   Reply With Quote
Old 01-01-2004, 11:34 AM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
Howard;
As far as the exhaust - what shape are your manifolds in?
If you are replacing everything, I think the consensus is that the Banks system is about at the top of the pile. Not to discount other midline (and more affordable) header systems, though.
As far as the header back, I think I would go with a custom shop. Probably a little cheaper, and you could go with a larger diameter and better grade of pipe at the same time.
With all modifications, keep in mind the goal to let the 454 breath better and get rid of the heat.
As far as the fridge, do a search on the forum threads. Several sites on the web also offer excellent troubleshooting procedures, and I have found replacement boards from Dinosaur to be quite affordable. I was able to redo both of my fridge boards for a couple of hundred bucks.
Good luck, keep the forum advised of your progress!
Dennis
WBCCI # 1113
AirForums #1737
Old 01-01-2004, 08:26 PM   #3
Astrodokk
Astrodokk's Avatar
Profile:  Santa Rosa , California
Do a search at the upper right hand corner for exhaust and anything else you may need info for. There are numerous threads on many subjects...I know, I was one rivet in my noob days.
Astrodokk is offline   Reply With Quote
