Old 06-20-2003, 06:17 PM   #1
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Entrance Door
I have read the other posts regarding adjusting the entrance door. Mine needs centered and raised at the latch side. If I loosen all four screws is there enough clearance around the screws to allow some adjustment or will I have to enlarge the holes in the frame of the motorhome to provide more movement of the door for proper alignment. What have others experienced? The door does not appear to be bent. There is plenty of vertical clearance between the hinge fastened to the door and the part of the hinge that is fastened to the frame of the motorhome to allow the door to be raised. It appears one could place small washers on the hinge pin between these two parts for vertical alignment. Thanks for any input, that is my project for tomorrow.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 06-20-2003, 07:11 PM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
just went thru the door hing thing. was a pain in the back... i would not play with the door other than replace the hinges, if they are worn, not a lot you can do with them. camper repair center has them in stock about $77 per hinge. tel 205-665-2531. not selling hinges but i messed with mine for several months and finally had to reolaced them. hinges were replaced at jackson center. and they advise you cant adjust them just replace. if you put shims in the hinge the seals will leak. some of the guys have put shins in to lift the door but that is a temporary fix at best. i wouldnt modify any holes that will come back and bite you in the #$$ if you decide to replace the hinges. lol
al
wb13798 is offline   Reply With Quote
Old 06-20-2003, 07:15 PM   #3
wb13798's Avatar
2004 28' Classic
dont know how far you are from jackson center. i think $325 is what it will cost to get airstream to replace. or you can get the hinges from them. lol
al
Old 06-21-2003, 04:44 AM   #4
The Hawk's Lair
cooperhawk's Avatar
Entrance Door
I am only 50 miles from Jackson Center so I have an alternative. I will see what happens when I loosen all the screws today and see how much movement there is. If there isn't enough then I agree with you, opening the holes will cause problems down the road when I have to install new hinges. Thanks for the input.
AKA THE GUNNER
VFW, LEGION, NRA
Old 08-26-2007, 04:59 PM   #5
Glen,
What did you end up doing about your door hinges? Our 310 has the same sort of problems and I'm looking for ideas.
frig door swelled, will not shut rockcutter Refrigerators 9 08-03-2004 06:37 PM
Entrance door hardware 72 Overlander 1 Doors & Locks 7 01-14-2004 07:17 PM
Entry Door Questions sladew Doors & Locks 22 12-13-2003 07:43 AM
Door Hinge Adjustment Cracker Doors & Locks 11 11-02-2003 07:24 AM
Outside handel for intrance door Sam Lawhorn Doors & Locks 2 08-20-2002 03:18 PM
