First thing I would check is the circuit breaker for the 120V outlet that the converter plugs into. On my 84 310 it is the GFI breaker in the 120V box.
I'm confused about the batteries. On my rig there are three batteries, two coach(house) batteries and one chassis battery. All of them are charged by the alternator but only the coach batteries are charged by the converter when the genset is running or when plugged into shore power.
The chassis battery is the only one used to start the engine (unless I use the battery boost). My chassis battery can not be discharged by house lights, furnace, water pump, etc. because it is isolated from the coach (house) load.
1984 310 Limited Motorhome
