Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 09-02-2002, 03:56 PM   #1
Jeb
Profile:
Angry Heater and Air Conditioner
Greetings to all A/S'ers...
Now for my problem. I have a 2000 Land Yacht that had a sick dash a/c. The a/c was fixed but now I have a different problem. When I put the climate control on "cold" and "vent" I get hot air through the vent. Changing the cold/hot mixer doesn't seem to help. When the a/c is on "cold" and "max" I get somewhat cool air. I know the a/c is working because I can feel the low pressure hose by the condenser and it's REALLY cold. I think the hot engine air is mixing with the a/c and making the air warmer. I have ACME controls. Has anyone experienced this problem? Is there something I could check and possible fix myself? Thanks all.
Jeb
berndt@berndtmd.com
2000 Land Yacht 35XC Diesel Pusher
Jeb is offline   Reply With Quote
Old 09-02-2002, 04:04 PM   #2
mkeith54
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
Is your heater hot water valve stuck open? If it is it would dilute your cool air. To tell see if both heater hoses are the same tempature at the heater core. One should be noticeably cooler than the other. If they are the same then see if the heater valve is closing all the way. If it is cable controlled and not shutting all the way the cable may require adjustment.
Mike
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Old 10-22-2002, 07:45 AM   #3
Jeb
Profile:
Here's the result: I put a pair of pliers on one of the hoses and the AC worked just fine after that. Althought the elecrtic valve appeared to be working it was not shutting off the hot water supply. Thanks to all that responded.
Jeb
berndt@berndtmd.com
air conditioner tinman7 Furnaces, Heaters, Fireplaces & Air Conditioning 25 05-09-2004 04:03 PM
water heater problem Stefrobrts Water Heaters, Filters & Pumps 4 10-23-2003 08:55 AM
40+ year old heater 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-08-2003 06:35 PM
Why is Airstream any better than the other brands? Narnian Our Community 54 08-08-2003 03:13 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
