Old 10-21-2014, 07:18 PM   #1
dump termination cap
1994 Land Yacht Motorhome. I lost my termination cap for the dump. The only ones I can find in local sources and so far on the internet are 3" and the AS needs a 4".
Any suggestions?
tuner is offline   Reply With Quote
Old 10-21-2014, 07:32 PM   #2
SStar's Avatar
2004 28' Classic
Midland , Texas
Dump cap
If the connection on your MOHO is a Thetford you might buy an adaptor from Thetford to Valterra then buy a Valterra cap (more readily available). Just remove the adaptor to connect your slinky or change your hose to Valterra. Something similar was just talked about in another thread.
SStar is offline   Reply With Quote
Old 10-24-2014, 01:03 PM   #3
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Don't know if this applies to your unit but this was a quick mod I did. Now I'm compatible with what's on the shelves in the RV section.
http://www.airforums.com/forums/f311...ml#post1301685
Air Dog is offline   Reply With Quote
Old 10-24-2014, 01:13 PM   #4
1974 Argosy 20
Kooskia , Idaho
A well stocked RV parts place can get you the Thetford cap you need. It is not 4" but different from the more common Valterra caps generally used today. They are still made, but a bit pricy.
Old 10-26-2014, 08:40 AM   #5
While looking for a Thetford adaptor I found not only the adaptor but also the cap I need on Amazon. Ordered both because the price was right. Thanks for your help!
Old 10-27-2014, 05:49 AM   #6
SStar's Avatar
2004 28' Classic
Midland , Texas
Adaptor
Glad it worked for you, now you should be able to use the off the shelf hoses and fittings that are available off the shelf.
Old 11-24-2014, 12:23 PM   #7
The adapter to convert the uncommon Thetford the the more common Valterra is Valterra P/N T05-2285VP. If you google this number you will find several sources. I got mine from Amazon. The price should be under $8.
Good to go. Need to find the next Airstream rally in my area.
Old 11-24-2014, 12:43 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Order more than one of the Valterra adaptors. As the ears break off easily. It should be made with 4 ears or at least heavier ears.
Black water tank termination cap gasket Safari64 Waste Systems, Tanks & Totes 1 10-01-2007 09:37 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Sewage/Termination Cap 1963 Globetrotter ShinyTiny Waste Systems, Tanks & Totes 7 03-09-2005 07:33 PM
