Old 04-22-2019, 08:13 PM   #1
Magnet18's Avatar
Churubusco , Indiana
Driveshaft Quick Disconnect
I'm looking at making my 4runner my toad behind my RV for flat-four towing. I'm not terribly opposed to crawling under and hooking up the driveshaft every time, but does anybody have any experience with the quick disconnects like this link, or the remco units?
https://www.trailtough.com/product/rear-drive-disconnect-for-toyotas/
It's not a rock crawler, just might want it for dirt roads the fit can't handle, and I can't sleep in the back of the jeep (and the 4runner is better in every way anyway)
Magnet18 is offline   Reply With Quote
Old 04-22-2019, 08:38 PM   #2
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Don't know of a quick disconnect, but isn't the 4Runner a bit heavy to tow with a classic?
Cheers Richard
tevake is offline   Reply With Quote
Old 04-22-2019, 10:13 PM   #3
Magnet18's Avatar
My 86 4runner is a convertible, with a soft top it is only about 200 pounds heavier than the Jeep I currently pull, and 500 pounds lighter than bobs chevy volt was... I figure it's worth a try
1983 Airstream 310 Class A Motorhome
-Rob
Old 04-22-2019, 10:26 PM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Whilst investigating the best approach for towing my Triumph Vitesse (which has an issue being towed as a the lay shaft will be turning un-lubricated), I had a circular/pointless discussion with Remco, first around if the disconnect would work, then only to find it can only be fitted to a limited number of specific models due to the mounting design. So I think you will have better success with the Toyota specific solution.
For me the best solution was to put the car in 4th gear (its stick shift) and depress the clutch.
martin300662 is offline   Reply With Quote
Old 04-23-2019, 03:39 AM   #5
Rob,
My mom and dad towed a Mazda pickup behind their 20' Coachmen for years using a driveshaft disconnect. They never had issues and it was quick and easy to use.
Old 04-23-2019, 05:12 AM   #6
Magnet18's Avatar
Originally Posted by bkahler View Post
Rob,
Thanks Brad!
Old 04-23-2019, 05:13 AM   #7
Magnet18's Avatar
That's not something I had thought of, thanks!
Old 04-23-2019, 07:08 AM   #8
Martin,
At one time I thought you were looking into a light aluminum trailer. Did plans change?
Old 04-23-2019, 08:24 AM   #9
Magnet18's Avatar
So what hardware do you use to keep the clutch depressed? I tried searching and didn't find anything. Homebuilt, or are there kits out there?
Old 04-23-2019, 09:07 AM   #10
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Iím in the clutch business, my 39th year.
I donít know what the toad is that this refers to but Iím saying highly NOT RECOMMENDED.
1. Any system that has a pilot bearing or bushing this technique is consuming the life of this small component. Itís normal use is only when the clutch pedal is pushed down during shifts or at a stop light for example.
2. Holding the clutch released and having the disc free spinning I can easily see the disc casually rubbing against flywheel or pressure plate casting. This casual contact will create completely unnecessary heat on the facing(s) and cast surfaces creating unnecessary facing and casting wear.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-23-2019, 09:19 AM   #11
Magnet18's Avatar
Gary
I can see your point, thanks for the info
I saw a simple idea recommended somewhere else, just leave the driveshaft off and simply run around front wheel drive unless I need 4 wheel
Old 04-23-2019, 10:49 AM   #12
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Totally home built, and literally no more than a length of wood from the drivers seat frame and two U-clamps.
In my case it was lesser of two evils (or rather 4 options). It is a 50 year old collector car so virtually no electronics to worry about, but that also means the oil in the transmission only circulates when the transmission is spinning - doing nothing (towing in neutral) was a bearing life-expectancy of 50-100 miles. Option two was to drop the drive-shaft (which also drops the transmission oil!). Option three was a trailer (and in European campsites there is no space to leave a trailer and a toad). Option four was leave it in gear/dip the clutch (and expect a reduced life-expectancy from riding the clutch).
Old 05-05-2019, 03:39 PM   #13
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
Remco has after market parts that can be added to vehicles making them towable on all 4 tires....but not all vehicles qualify!! The Ford Sport Trac is a good example.....everyone wanted to pull those around but once Ford stopped supplying parts, it ended.
Good luck....I just stick with Jeeps and pass everyone else on the road
Mike1997 is offline   Reply With Quote
Old 05-05-2019, 04:18 PM   #14
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Martin,
Yep.
I managed to source an A-Frame with an inertia brake for $120 (basically as the vehicle slows the vehicle being towed compresses a lever, that pulls a cable setup to depress the brake pedal).
The issue is on my Vitesse the lay shaft turns when the prop turns, but is only lubed when the gears are rotating (literally splashing the lay shaft bearing). So although it is 'stick' and can happily be flat towed, the lay shaft bearing will be destroyed quite quickly if the gears aren't rotating.
At the moment the attachment of the A-frame to the front chassis is not clean. With mounting brackets going under the front valance, lowering ground clearance. The brackets are in a local shop, and a new sub-frame is being made that attaches at the front over-riders (which bolt to the chassis). However they have to cut-up the original over-riders for that to work so I am trying to source some replacements before the cut into them...just in case it doesn't work out!
1983 310 Turbo Diesel-Driveshaft removal DataMover Mechanics Corner - Engines, Transmission & More... 7 10-25-2017 03:05 PM
Has Anyone Ever Sheared a Driveshaft? Rpatrick16 Tow Vehicles 6 03-08-2017 07:28 AM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Driveshaft balance on MH RichardT Airstream Motorhome Forums 3 12-07-2004 11:47 AM
