Old 05-05-2019, 05:44 PM   #15
Originally Posted by martin300662 View Post
Yep.
I managed to source an A-Frame with an inertia brake for $120 (basically as the vehicle slows the vehicle being towed compresses a lever, that pulls a cable setup to depress the brake pedal).
The issue is on my Vitesse the lay shaft turns when the prop turns, but is only lubed when the gears are rotating (literally splashing the lay shaft bearing). So although it is 'stick' and can happily be flat towed, the lay shaft bearing will be destroyed quite quickly if the gears aren't rotating.
I wonder if you could add some sort of recirc pump that routes between the drain plug and the fill plug on the side. If setup probably you might be able to create a splash condition with the oil. Of course if the bearings need to turn that might not be a solution.
At the moment the attachment of the A-frame to the front chassis is not clean. With mounting brackets going under the front valance, lowering ground clearance. The brackets are in a local shop, and a new sub-frame is being made that attaches at the front over-riders (which bolt to the chassis). However they have to cut-up the original over-riders for that to work so I am trying to source some replacements before the cut into them...just in case it doesn't work out!
Would these over riders be what you're looking for?
Old 05-06-2019, 01:22 AM   #16
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Yes Brad....and only 20miles from me!
martin300662 is offline   Reply With Quote
Old 05-06-2019, 03:40 AM   #17
Now you just have to win the auction
1983 310 Turbo Diesel-Driveshaft removal DataMover Mechanics Corner - Engines, Transmission & More... 7 10-25-2017 03:05 PM
Has Anyone Ever Sheared a Driveshaft? Rpatrick16 Tow Vehicles 6 03-08-2017 07:28 AM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Driveshaft balance on MH RichardT Airstream Motorhome Forums 3 12-07-2004 11:47 AM
