Old 12-06-2004, 04:02 PM   #1
RichardT's Avatar
Driveshaft balance on MH
Check this out, it is an active balancing system for the driveshaft.
Has anyone had any experiance with these?
How much does it cost to get the driveshaft balanced professionally?
I am doing u-joints and the carrier baering this week as well as fluid change in diff, new shocks all around, new dampner, wheel bearings etc...
and came across this.
http://www.balancemasters.com/driveshaftdesc.html
RichardT is offline   Reply With Quote
Old 12-06-2004, 08:03 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Richard,
Uhg - been there done that on the bearings, u-joints, shocks and bearings....not a lot of fun but what a difference!
I am still chasing vibrations out of my drivetrain. I think it's isolated to a loosening output shaft from the transmission. This device sounds good but I'd like to hear from someone who's used it. The website leaves a lot to be desired.
One thing I've noticed since doing all of the same things is that all the noises, creaks, rattles and groans from the suspension/drivetrain are gone but now I can hear all of the noises, creaks, rattles and groans from inside the coach - kind of like that "whack a mole" game at the county fair.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 12-07-2004, 02:25 AM   #3
LOST , Hawaii
$230 to get one shortened, balanced, 3 new u joints and a carrier bearing. I thought that was a steal considering I paid $180 for 1 U joint to be replaced last spring on a SOB.
FWIW, it was a 1990 P32 chassis and had inverted torx head bolts on the rear axle caps. If you have one around this age check the bolts before you end up in a jam and have to fork out big bucks for a simple job.
John
74Argosy24MH is offline   Reply With Quote
Old 12-07-2004, 11:47 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
My brother-in-law is a machinist that specializes in drive-line and truck axle repair. just "balancing" the driveshaft takes him about 5-10 minutes. I can't believe he charges much for the service...I've seen him do it a hundred times...fairly simple operation. but the machine costs an arm and a leg, I guess. I can find out how much, if you're interested.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
"We don't normally balance trailer tires....." Pick Tires 36 07-16-2012 02:30 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Running gear balance? Cedars Axles 79 06-10-2004 02:57 PM
Tire balance Melvin P. Thorpe Tires 12 12-30-2003 07:21 AM
RV weights and balance gwsullivan Link Archive 0 08-21-2002 02:50 PM
