Old 06-26-2019, 07:23 PM   #1
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Drivers side valve cover relay.
Hey,
What is the function of that relay on the drivers side valve cover. It's got 4 wires going into it. It's about 2 3/4 wide about an inch and a quarter long and about 3/4 on an inch thick. I ask, because the connection is all funky. Almost like it gets hot and melts a little.
Is it nessessary. Who does it relay. Thanks DJ
davejay is offline   Reply With Quote
Old 06-27-2019, 12:19 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
There might be a starter relay in that neighborhood.
Waipio Rim is online now   Reply With Quote
Old 06-27-2019, 07:21 PM   #3
Hey,
It could be a starter relay. In the front dr side, there are wires that are the same size and color as these going to the relay. Could be blinker or marker light things. I haven t really spent to much time thinking about it. Just thought maybe someone may know about it. Thanks DJ
Old 06-28-2019, 07:46 AM   #4
The relay on the passenger side that is mounted on the bracket holding the dip tube is a starter relay to help in hot start situations. The relay on the driver side is most likely an emissions relay. At least it was in 86.
Old 06-29-2019, 06:02 AM   #5
Hey,
I think your right. When we bought this unit, it had no emessions stuff on it. It doesn't appear to go anywhere, or do anything. Thanks, I lol just leave it there plugged in. It's not hurting anything. Thanks again. DJ
Old 06-30-2019, 06:35 PM   #6
1982 28' Airstream 280
Redwood City , California
Is this the relay you're talking about? I've been trying for 10 years to figure out what it does.
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 07-01-2019, 03:28 PM   #7
Waipio Rim's Avatar
Honokaa , Hawaii
If anybody has a part number or source for that starter relay, I need one.
Old 07-01-2019, 04:05 PM   #8
This is the one I used.
ford starter relay
Old 07-01-2019, 05:55 PM   #9
Hey,
Yup, that's the one. It's got a yellow,blue, black, and I think a white wire.
I'm thinking it's got something to do with the outside marker lights.
Could it be a voltage regulator for lights? That wire group goes down the left side of the motor by the master cylinder. DJ
Old 07-05-2019, 03:25 PM   #10
I figured out what this is...engine speed switch.
see the following link for an explanation...
https://www.autozone.com/repairguide...00c1528004c499
Old 07-06-2019, 05:44 PM   #11
Hey,
Wow, you are something, you took the time to look that up? Thanks, who d ever thing that relay had something to do with the carberator.
Well, I now have a FI tech fuel injection system installed on the 454. So this relay is not needed. You think I should disconnect it? Could it mess with the timing being it works with the tach. Thanks again, DJ
Old 07-06-2019, 08:10 PM   #12
If you live in a state that does not require smog checks which I assume you do since you installed a FI system, you could remove it. It only takes a tach signal from the distributor to turn on/off the relay at that certain drop in rpm. So no affect on any other operation of timing etc.
One of the reasons I finally wanted to figure out what it was for was in case it went bad out on the road and I was wondering if it would stand me. Iím not worried about it now.
Iím jealous because I would love to remove the Quadra jet and install a throttle body FI like you did but living in California, I canít change or remove a single thing and still be smog compliant.
Oh boy, I can here the non-Californians chiming in already, but I have to tell you that Iíve lived here for 52 years and it sure is nice to be able to breath fairly clean air. For example, my tool truck is a clean idle diesel and it sure is nice to be able to let it run all day in order to run the A/Cs.
If I were you, I would at least keep all the old carburetor and smog parts for that day when you might sell your coach and that one and only buyer lives in one of the ever increasing in numbers smog states.
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
81 Excella 280 Turbo Diesel - windshield and drivers side mirror mount? dlcain Classic Motorhomes 3 08-05-2010 09:44 AM
Drivers side window fogged keenstreamer Windows & Screens 0 08-13-2009 05:32 PM
What is the relay on the drivers side valve cover? RichardT General Motorhome Topics 4 03-18-2008 06:58 PM
Drivers Side Window Replacement vasellers Classic Motorhomes 5 05-08-2007 03:23 PM
