Old 09-13-2019, 07:34 PM   #1
airmack
1989 37' Airstream 370
Howick , Quebec
Donor Truck
Hi Just bought my donor truck for a diesel transplant in to my 1989 370 LE. A 1997 cummins diesel turbo intercooled and air to air with a 47 re transmission, good winter porject. Malcolm
airmack is offline   Reply With Quote
Old 09-13-2019, 08:01 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
That sounds like a one fine transplant!
I wish I lived closer, would love to see it up close. Iíve done several engine swaps in my garage but your diesel donor in an Airstream motorhome is very cool.
Please post photos and status updates during the process. Good luck!
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 09-14-2019, 03:51 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Airmack,
That is a robust old school Cummins. I owned one. Just checking, are you aware of the killer dowel pin KDP status on your donor engine?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-14-2019, 06:41 AM   #4
airmack
Howick , Quebec
killer pin
Yes I am, I've done a gas to 5.9 diesel before, thanks for the concern. Malcolm
Old 09-14-2019, 07:57 PM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Pretty cool...,,Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 09-21-2019, 01:53 PM   #6
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
That is very cool.
Could you document your swap. A 5.9 will fit right in there with a little fabricating. But the weird stuff like wiring it, the brake drum on the trans , those are the adventure part of the swap I don't like.
I had a 91 pickup w a 5.9 and a 5 speed manual. Loaded all the time, it pulled 18.7 mpg went to Canada once. 2 tanks up there, 23.5 mpg. Go figure. Better fuel I guess. My dodge weighed in at just over 8000 PDs. You should get at least 12-14 mpg I would think. Those engines are bull it proof. Gas mileage went up even more when they went to the 32 valve system. But it got more complicated from a wiring standpoint. I'd be very interested in your setup. I can alway pull my 454 and stick it in something else. Maybe a 55 Chevy. DJ
davejay is offline   Reply With Quote
Old 09-22-2019, 07:24 AM   #7
airmack
Howick , Quebec
Doner truck
Hi This is going to be a winter project. My truck is a 97 the last year with a mechanical pump and a 47 re transmission which I'll get beefed up. When I start I'll post lots of pictures. Malcolm
Novel use of our donor Argosy martin300662 Argosy Motorhomes 10 07-06-2015 06:30 AM
Out w/the old and in w/New@or Donor Parts Airdaddy Refrigerators 11 07-22-2011 08:06 AM
Just bought my cummins donor vehicle gwbaker Classic Motorhomes 120 05-23-2011 05:30 PM
Organ Donor Awareness mffjm8509 Our Community 9 05-21-2010 09:41 PM
panel donor? goransons Ribs, Skins & Rivets 2 02-18-2009 10:29 PM
