Old 08-04-2016, 02:55 PM   #1
wimberley , Texas
Dometic AC issue
Fan would not start but compressor kicks on. I can get fan started with a screw driver and it will than run. Replaced start capacitor it still will not start fan. What next?
John Stark is offline   Reply With Quote
Old 08-04-2016, 04:51 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Fan Motor. Not sure if it will come out without moving the condenser coils but if it will that may be the way to go.
Don't run the compressor without the fan for more than a few seconds. You will build high head pressure.
2004 Excursion 4x4
Old 08-04-2016, 06:15 PM   #3
1981 31' Excella II
New Market , Alabama
Well most likely the sleeve bearings have dried up and the friction has gone up to where it won't start without help. Does the shaft have any resistance to being turned? The fan should spin freely without power. If it is stiff the bearings are gone and can't be fixed. Probably $150 for a new motor. If the town you live in has an electric motor shop they can test it and match up a new one. You might be able to order one from Grainger or even Dometic.
Perry
Dometic CC2 issue, or not? Gsmblue Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-10-2017 08:30 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
1976 Argosy 24' - Dometic Refrigerator issue NAM_FL Refrigerators 1 05-21-2013 10:51 AM
Dometic Fridge issue vicn2000 Airstream Trailer Forums 1 05-02-2012 10:15 AM
Dometic propane re-light issue Boondocker Refrigerators 15 02-09-2011 11:47 PM
