Old 09-06-2003, 02:09 PM   #1
1978 28' Ambassador
Smartsville , United States
Disconnecting toilet from tank
I am attempting to remove my whole toilet assembly from a '73 Airstream Land Cruiser so that I can put in a composting toilet.
I don't see how the toliet (which is firmly mounted to the floor) comes free from the plastic tank below. After that I also need some advice on how to seperate/disconnect the tank from the dump vlaue below it.
Much obliged for your knowledge.
vishwa
vishwa is offline   Reply With Quote
Old 09-06-2003, 02:25 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
There are two "closet bolts" holding the toilet down to the tank cover. one is in front, just behind the foot pedals. that's the easy one. the other one is in back. You might be able to access it through the access plug in the rim of the toilet. Open the toilet seat and lid, and you'll see a "plug" like thingy toward the rear of the toilet bowl on the left hand side. If you remove that plug, you can look down in there and see the other bolt. you "should" be able to get a socket on a long extension on the nut that is holding it on, but I couldn't on mine, because the bolt was so tall, there was no way to get a socket over it, as it stuck up very close to the underside of the toilet bowl. So I had to contort myself to get a box-end wrench on it from behind. Then I found that someone in the past actually cut an access hole in the skirt on the left hand side....you don't see it, as its so close to the wall there. even through that hole, it was still tough to reach. anyway....that's how you do it on a 1973 safari land-yacht. not sure what your trailer is...never heard of a "land cruiser" before.
can't help you with the rest; what you're describing would take some extensive modification in my trailer, as the vanity, which is connected to the shower, sits on top of the black tank/tank cover. you'd have to re-design the whole bathroom, really. good luck!
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
cleaning up toilet tank release handle CindyH Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
