Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 06-03-2004, 09:52 PM   #1
LKappenman
Finally Retired
Profile:  , Washington
Diesel engine and alternator
I have just heard from a friend who has the izsuzu engine and has a alternator problem whe had our rebuilt 2 years ago and so far so good. He has had his rebuilt twice now and now the mechanic says the constent noise he is heaing is the alternator. The rebuild was done on vacation in Ca and he is in Mt. When he had it rebuilt and got it back he heard the noise so they took it out again and said the it was a bad bearing so the redid it so that made twice in a week of course there wasn't a charge for the fix. Noise is still there the drive home was fine charging was fine just the noise. Any ideas? warranty is 1 year but big deal if it is 1500 miles away. He originally took it in because the tach wire had burned.
Any help is appreciated
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 06-04-2004, 05:41 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Another bad bearing. If the setup was wrong when they started the run the whole run could be bad. Shaft worn or bore the bearing is in is bad. Maybe not the alternator, could be a water pump, ps, ac clutch, etc. Sometimes it is hard to pinpoint accessory noises, they are all close, you can't really get at the front of these engines very well.
John
74Argosy24MH is offline   Reply With Quote
Old 08-14-2004, 05:33 AM   #3
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 143
Originally Posted by 74Argosy24MH
Another bad bearing.......you can't really get at the front of these engines very well.
Amen......
Given the difficulty of access, and the probability that if a failure occurs it will be about 1500 miles distant from the point of purchase, my philosophy is to go with new premium "accessories" (pumps, alternators, starters, etc.).
Like John stated above, often the rebuilds are not quite up to the same standards of a premium new manufacture. Sometimes it's just best to put out the bucks on the first fix to insure that you don't have to do it again on the road.
JMHO.
Dennis
WBCCI # 1113
AirForums #1737
Old 08-14-2004, 07:11 AM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
have to go with dennis on this one,
new parts in this case might be the best route to go. especially if access to it is an issue.
on my two prior tow vehicles alts lasted about 80,000 miles. mr. good wrench always stood by the warranty. that goes for water pumps too!
on my 2000, the 140 amp alt made it 28,000 mi before self destructing in a snow storm, it was changed out for a new one under warranty. no problems since.
i guess you can get a bad one every once in a while new or rebuilt.
john
you call them ferrets, i call them weasels.
Old 08-14-2004, 07:36 AM   #5
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
many mechanics will try to isolate the noise using a tool, such as a long rod they listen thru to see where it is actually coming from. The water pump could be a suspect as it is so close to the alternator. Also the belt could be loosened for the alt and then see if the noise goes away, running a few minutes with no alt spinning.
If it is the alt..then new parts are the deal. I got mine thru www.4altertstart.com
in Dallas, they build their own with gm cases, and they are seriously put together.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-14-2004, 07:53 AM   #6
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Dave,
Here is the thread where you went into the fact that a new one costs BIG $$$. Is there a possibility for a boneyard unit to see if the current shaft is just too worn?
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-14-2004, 09:15 AM   #7
87MH
87MH's Avatar
Images: 143
Cost of new Nippon Vacuum/Alternator
Wow:
Just read the 2002 thread - hard to believe.......
Given the new cost and how long the rebuilt last, I would have to believe that a new (non-Nippon) heavy duty alternator and new SOB vacuum pump and Southern Engineered Bracket would be the way to go.
I replaced the vacuum pump on the E-350 7.3 liter diesel a couple of months back - I think it was around $75.
One comment on the new alternators - I was in a Peterbuilt service shop the first part of this year - they had a whole pallet of new 150 amp self-regulating alternators for $120 each - don't remember the brand - I guess if you have remove everything anyway it would be worth the effort to look around at options to avoid a $600 alternator.
I would be sorely tempted to replace EVERYTHING (water pump, fan clutch, belts, hoses, thermostat, etc,) while I had it stripped down enough to get to the alternator.
Dennis
WBCCI # 1113
AirForums #1737
Old 08-14-2004, 09:45 AM   #8
74Argosy24MH
Best advice you have gotten. Nippendenso starters and alternators are not long lasting. It is not that hard to convert to something else, it will be worth it in the long run.
John
Old 08-14-2004, 06:44 PM   #9
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
IIRC, those alternators have a vacuum pump mounted on the rear. The noise could well be coming from the vacuum pump, that could be why a rebuild/replacement didn't eliminate the noise.
Change is inevitable, except from a vending machine
AIR#2611
Old 08-15-2004, 05:56 AM   #10
ctdair
ctdair's Avatar
Profile:
Proper tension on the belt is critical , if over tensioned it will take out bearings in alternator and or water pump. After your reinstalation dont be overly agressive in tension , there are belt tension measuring tools but most are hard to use in cramped areas.
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2002 Dodge Diesel 4x4 Dually
ctdair is offline   Reply With Quote
Old 08-16-2004, 08:24 AM   #11
LKappenman
Finally Retired
alternator
I will pass this on havn't heard from him in a while so probably fixed by now. I remember when we had ours done could not beleive the cost.
Dave and Louise
#2852
Finally Retired
Old 08-16-2004, 10:10 AM   #12
overlander63
Images: 58
The last one I replaced was $650.00 my cost for the part only. After markup and labor, the customer's bill was well over $1000.00
AIR#2611
Old 08-16-2004, 11:07 AM   #13
74Argosy24MH
D E L C O
John
Help on engine RonJudi Mechanics Corner - Engines, Transmission & More... 67 04-04-2007 09:50 PM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
Emergency parts Bill Resseau Mechanics Corner - Engines, Transmission & More... 11 04-23-2003 09:21 PM
Electrical Problem NASCAR345 Airstream Motorhome Forums 15 03-13-2003 06:23 PM
