Old 09-06-2002, 04:37 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
dead battery-revisited
On my recent trip to Alaska, I spend some time with Curtis trying to figure out the motor battery drain on his 1979 MH.
Facts:
disconnected + from generator, no help
replaced bad battery isolator
replaced bad headlight switch (low beam would randomly turn off)
its not the step switch, since it is vacuum operated.
the radio is wired to the coach batteries
Besides bad diodes in the alternator, what else could cause a constant drain and sometimes a dramatic overnight complete discharge. The battery is new.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-06-2002, 07:49 PM   #2
Peter.
I would get an ammeter and start looking. It's the only way you can positively identify any mysterious drain.
But, don't assume that brand new batteries don't do crazy things, because they do.
Therefore you could chase a drain for hours, only to find perhaps a battery that's bad.l
inlandrv.com
airstreamparts.com
Old 09-06-2002, 10:15 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Drain...
PeterH,
Not sure if this is related to your situation but, last year when I finis my tour out with the A/S..I parked in a local parking lot overnight and, the next morning when I went to start up my Burb..the batteries were dead from just sitting overnight..Left the power cord hooked up overnight and, the refrig, being a 3way unit must've switched to 12volt during the night..Drained it completely..Just my two cents worth..
I know were talking TT AND MH here but....
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 09-07-2002, 06:05 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You know the problems i was having, were all related to the wiring going from that small terminal box to the starter solenoid.
The wires looked fine until you looked closer and saw that they were basicallly burning through from heat. The color of the insulated jacket was even normal looking, but the wire inside was down to just a few usable threads. May not be Curtis' problem, but it sure took meawhile to find it on my rig. Cured all my electrical difficulties, and probable was what made my battery isolater look bad. I will bet the isolater (long thrown away) was ok.
Old 09-07-2002, 06:09 AM   #5
Airstream Driver
1997 30' Excella
Images: 51
Andy, according to Curtis, the battery was new and bad. This 'new' one is a replacement. But who knows...
towner7, we ran the refer on gas and electric only.
I use a little indicator light for the 12V functions of these old refers. Wired to the 12V out terminal of the small relay will tell you when you are on 12V.
AIR #13
Old 09-07-2002, 08:34 AM   #6
Larry Brown's Avatar
sameo
I just started to have the same problem, My batteries (coach) both just died they were dyehard golds 7 years old .So I thought ok they served thare time so I purchased 2 new exide automotive type batts as were the others auto type (non deep cycle) over the time of less than a month they both died. They will charge up but do not hold a charge. I wonder how something could develop a short or a drain just sitting there as this is what happened .I now just flip the dissconect switches from the batteries when I hook up to power or I'm not going to use it for a while. What should I check for?
Larry Brown is offline   Reply With Quote
Old 09-07-2002, 09:37 AM   #7
LOST , Hawaii
As Andy said the only way is with an ammeter. You can pull fuses and see if it stops, but there is a lot of wiring that does not go through the fuse block, or it could be shorted before the block. It is time consuming, but really is the only solution.
John
74Argosy24MH is offline   Reply With Quote
Old 09-07-2002, 10:56 AM   #8
, Alaska
Hi,
First of all, thanks for your time and effort.
I was just casually reading these posts when I noticed LARRY mentioned Exide batteries....both the new battery that went dead (and needed a replacement, under warranty) and the current battery that goes dead after a few days are both Exide batteries....
Peter and I tried to figure the battery problem out using a voltmeter and prior experience (mostly Peter's!). At one point we thought we had been successful only to be disappointed with a dead battery a day or two later.
Both Andy and John mention using an ammeter to run down this electrical problem. Any ideas how, and where, to begin using the ammeter? I read that I should check the fuse box. I guess that means the P-30 fuse box, correct?
ALANSD mentioned the "small terminal" box to the starter. Where is the small terminal box? Do you mean the one mounted near the engine? I replaced that, but did not investigate the wiring in depth....I will.
What about the alternator diodes? Peter mentioned that someone had a problem with the alternator leeching from the battery and the culprit were the diodes in the alternator.......
I'll stop this lengthy inquiry while wishing you all charged batteries, and your only shorts in life are the ones you have to launder.
Curtis-79MH
Curtis-79MH is offline   Reply With Quote
Old 09-07-2002, 04:21 PM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yes you have the right terminal box. My wires to the starter solenoid looked ok at a casual inspection, but they were fried fron heat, and got worse as time went on to the point of having not enough strands connected. First my tv/vcr did not work right.
The tv played but vcr would not come on. Weeks later- the horn and lights died. Then the volt meter started going progressively down from 14+ to 11, stayed there a while then went to zero.
All the while my battery got weaker and weaker. I checked alternator output, battery isolator outputs, and so on. The wires at that point did not look bad to me. Eventually, after replacing the alternator and the isolator- (a technicians not very good advice)- my rig just would not start.
Left me in the dump area of a state park. I got underneath and the starter wires were burnt down to one strand holding on to the solenoid terminal. I jumped the starter, got it home, and the whole solenoid cover and terminals came apart in my hands.
Sorry for the long tale...but this all happened over a 4-6 week period, during most of which I was on the road a long way from home.
Old 09-07-2002, 06:12 PM   #10
LOST , Hawaii
Before you start I would definitely take the battery and have it load tested. You have had a bad one already, it is quick and easy compared to what you have to do.
Everything must be turned off, but don't make any valiant efforts to do so. If a switch is sticky, it could be the problem. Just make sure all switches are off as normal.
A clamp on ammeter is the only way to go. An inline meter requires you to unhook and hook each wire you check. A chassis schematic is nice to chase circuits but not necessary.
Start checking at the battery hot. It will hook to the solenoid and several wires should feed from it. You should have a current flow at the battery, keep following it down through the smaller wires. This is where the schematic is nice, but if you don''t have one follow the loom until you can get at the wire again. At each junction follow the wire with current flow.
There may also be a terminal block on the upper alternator bracket. Check it and any other large red wire you see, it will eventually feed several circuits. The light and ignition switches are also major feeds. Don't forget the circuits added by POs, fog lights, cb's, other accessories.
John
Old 09-07-2002, 07:19 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
John
a clamp on ammeter will only work on ac circuits, you will need a series connected meter on dc
john
Old 09-07-2002, 09:52 PM   #12
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
Hi everyone;
I've I thought I would give my thoughts on this problem. I'm going to make some assumptions and they may not be correct. If anybody knows differently please inform the forum because the documentation I have is a little bit sketchy on some of the finer points on the Univolt system. The assumptions that I'm going to make is that the battery is good, the isolator is functioning properly and that the charge lead from the Univolt is not interacting with the chassis electrical system. Since we don't have an ampmeter available will have to take a little bit different approach to this. First take your volt meter and make a quick rating on what the battery voltage is, we are going to assume it's between 11 and 12 volts. Now disconnect the negative lead from the battery and measure between the battery terminal and the cable clamp. If there's a significant current drain that voltage should be the same as the voltage measured across the battery terminals. If you are reading at a much lower voltage it means that the resistance of volt meter is actually pulling down the voltage so there were to be enough current drain to use the lightbulb method to troubleshoot this. The next step is to take a automotive 12 volt lightbulb and connected between the negative battery terminal and the negative cable and hopefully there's enough current flowing that the filament will glow. If you have this condition the next thing to do is get a helper to pull out the fuses on the chassis fuse panel one at a time and see if the lamp ever does out. This will identified the circuit where the leakage is. And once we know that then we can make some guesses about what we should do next. If you don't have a helper you can put the cable back on the battery and wire up your lamp with a couple wires and as you pull out a fuse place the lamp in the circuit where the fuse was and if there is current flowing in that circuit then it should glow as brightly as it did when it was connected to the battery terminal. If going through this procedure and the light remained on then we got to start looking at the unfused portions of the circuit. This would be the leads to the alternator, the starter, or perhaps even the vehicle side of the isolator. This is where are I have a shortage of knowledge so if anybody knows how we can isolate the unfused portion of the circuit please chime in. We may have two problems because as I understand it sometimes the battery discharges slowly and other times there is a rapid discharge and we may only fix one problem and then will have to address the other.
Hope this helps.
Bill
shelocta is offline   Reply With Quote
Old 09-08-2002, 04:46 AM   #13
LOST , Hawaii
A clamp meter with a hall effect transducer will measure dc current. AC only use transformer input.
Bill- If you pull the battery cable and place the meter between the cable and battery post the meter will become part of the circuit. If it is set for volts it will blow the meter fuse or the meter movement. The test light will work, once you have pulled the fuses, I would look on the alternator bracket for a terminal block and follow any large red wires which should feed several circuits. Don't forget the accessories added by previous owners.
John
Old 09-08-2002, 08:25 AM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
John
correct!
john
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
