Old 08-25-2009, 06:41 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Dash Heat & Air Switch and Vacumn Lines
I have a 2003 Airstream LY 30' Gas. I'm getting ready to hit the road and discover no dash air/heat/defroster or fan will operate. I check all the under dash and under hood CB's. Under the hood I noticed the white vacumm line from the port on the back of the heater is completely dried up and split. It literally turned to dust. I understand that without this hose connected to the dash switch, the doors would not open/close properly, but I don't understand why the fan does not work on any speed.
I need some advice please.
I can live without A/C but I may need the blower to function for defroster air. Do I need to remove and replace the switch ? Thanks.
Steve
spat61 is offline   Reply With Quote
Old 08-25-2009, 07:19 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Workhorse chassis.... correct?
The symptoms usually start with the lower speeds not working, but I would check the blower speed resistor first.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-04-2018, 12:52 PM   #3
2004 30' Classic
2004 30' Land Yacht Gas 30
Lake Wales , Florida
The blower speed resistor is located under the hood on the passenger side high up on the ac/heat case. You can get a new one at the auto parts store.
Jdowen is offline   Reply With Quote
Argosy Dash Air Conditioning Wardman Argosy Motorhomes 13 11-26-2012 05:58 AM
Help with Heat/Defrost/AC Rotary Switch spat61 General Motorhome Topics 1 05-15-2009 08:30 AM
Air pressure dash gauge raveson Classic Motorhomes 1 03-11-2008 09:59 PM
Dash Air tn2 Mechanics Corner - Engines, Transmission & More... 10 07-12-2007 01:52 PM
'86 345 heat/ac vac lines Nicksays Mechanics Corner - Engines, Transmission & More... 14 08-28-2006 07:32 PM
