Old 07-13-2003, 01:50 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Question Dash AC blower motor
After driving 30-45 min with the Dash AC on, the blower motor slows down to a point that hardly any air is moving. I still can hear the switching to the three stages, lo med and hi,
but no air. After an hour or so turned off, the cycle starts again.
Motor going south???
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-13-2003, 03:19 PM   #2
71tradewind's Avatar
Peter i have had similar problems with GM blower motors and have been able to remedy it by drilling a 1/16 or smaller hole"only drill deep enough to go thru the sheet metal" on the bearing end "ie" the bump on the end of the blower motor housing, opposite end from the the fan itself, then I put a few drops of 3in1 oil into the hole in hopes of lubing the bearing /bushing. then clean the hole with a degreaser and put a dab of RTV to cover the hole. I hope this works for you. Tom
71tradewind is offline   Reply With Quote
Old 07-14-2003, 01:43 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Peter.
I experienced the same thing on the way home form Dallas in MH #2. I belive it was the evaporator freezing over and not allowing air to pass. I turned the temp down so the compressor would not cycle and the air flow slowly got better and came back to normal. I have a weird groan in the motor when it starts or is on low, so I am going to need to replace it but it worked for the trip home just fine.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-14-2003, 02:12 PM   #4
Good point Brett ! My tow vehicle was doing that last week.
Old 07-14-2003, 02:47 PM   #5
Airstream Driver
1997 30' Excella
Images: 51
Thanx for the replies.
Tom, I went in there a few weeks ago and "injected" some lithium grease on both ends (two shafts coming out of this motor) with a make-shift tube extension for the spray can. That did not fix it, if the bearings really are the problem. I may have to dig deeper, as you suggested.
Brett's comment got me thinking. When this happened the first time I noticed water running out of the AC drain pipe long after I shut the motor and the AC of. Kinda puzzled me. The freezing over would explain it.
Brett, the groan you hear could be the fan(s)
hitting the fan housing. I had the same problem and fixed it by unscrewing the motormount and slightly moving the motor to one side. It's extremely hard to reach.
AIR #13
Old 07-15-2003, 05:38 AM   #6
Airstream Driver
1997 30' Excella
Images: 51
hmmm, hanging at the local Airstream lounge, I overheard 59toaster saying to thenewkid64:
>>The A/C may be over charged. Take it to a local place and probably looking at just a few bucks to fix that up.<<
I drove 1200 miles with the AC blasting and then when leaving Lubbock, Texas the problem started a few hours into the trip.
Simple logic would indicate that freezing over may not be my problem....
AIR #13
Old 07-15-2003, 06:01 AM   #7
Chas's Avatar
Images: 22
Peter,
Sounds to me like it is freezing up which is a symptom of it being either undercharged or a loss of airflow. Fans will make strange noises whenever they can't move air, running in a stalled environment as with a blocked evaporator core. I don't like messing with auto a/c's myself, for the most part I will only do my personal vehicles and that's it, they are just plain frustrating to work on, too many variables. But, if you need some help on it just drop me a line.
Chas
Chas is offline   Reply With Quote
How would you rebuild the motor if you had to? Impala SS Guy Airstream Motorhome Forums 8 01-18-2008 07:56 PM
motor home 454 engines (motors) wb13798 Airstream Motorhome Forums 6 01-31-2004 09:26 AM
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
dash ac wb13798 Mechanics Corner - Engines, Transmission & More... 7 05-17-2003 09:06 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
