Old 08-15-2015, 02:29 PM   #1
1999 35' Cutter Diesel Bus w/slide
Harrisburg , Pennsylvania
Cutter thermopane window seal
The thermopane window seals have moved up between the two panes of glass and in the process smeared the sealant on both of the pieces of glass. Does anyone know a fix or where I can get replacement windows reasonable.
johnleidy is offline   Reply With Quote
Old 08-15-2015, 10:04 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
If you get to FL, look up Suncoast Designers in Hudson. They remove the window and frame from the coach, disassemble, clean, re-seal and replace.
Excellent work for a reasonable price.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 08-19-2015, 10:23 AM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Same at the www.rvfogdr.com had mine done there.
Peter
PSchw is offline   Reply With Quote
Fogged Thermopane Window Fix! Donald Windows & Screens 17 06-22-2010 08:16 AM
Gummy crap between thermopane windows Robin Stone Windows & Screens 2 12-19-2007 05:44 PM
Thermopane Window Redbird Windows & Screens 2 05-21-2007 02:04 PM
thermopane windows art 1974 - 1979 Sovereign 2 12-27-2002 05:48 PM
thermopane glass Chas Windows & Screens 1 12-27-2002 04:52 PM
