Old 12-26-2015, 01:22 AM   #1
coairstream's Avatar
1988 34.5' Airstream 345
Denver , Colorado
Cost of a new water heater
Merry Christmas!!Since its late I'll get straight to the point. We are traveling and are in New Port beach. We lost hot water a day ago and I had some time to investigate tonight. I found the carpet and floor wet under the couch wet but not soaked and the cardboard socked several inches up. I tried to upload a pic but it's taking forever. I'm assuming I'll need to replace it and will look for someone local tomorrow. Possibly the dealer. How much should I expect without taking it on the chin?
Thanks for the help!!!
Cody
coairstream is offline   Reply With Quote
Old 12-26-2015, 07:34 AM   #2
Cody, the last two water heaters I bought were from ebay and cost about $380 each. There were propane/ac type heaters.
I would expect the dealer to be several hundred more just for the heater plus your install at probably $100/hr. Hard to say how many hours to do the job but I would bet a minimum of about 3.
Sorry I'm not much help.
Old 01-29-2016, 01:58 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Post #2 sounds about right - I don't do a LOT of labor myself but I DID to a "tool gofur" role when a neighbor with a SOB moho replaced his. I think with a helper I'd be able to do this job myself. It's the wiring parts that worry me, but if the wires are color coded I'm good.
Physically manhandling the water heater into place is awkward but doesn't require massive strength. A lot depends on whether you have to disassemble half of the inside to get it wired up. Kinda looks like my 25 FB might be one of those... your classic moho? Get the .pdf drawings.
I hesitate to mention this - but with big bucks you could get a tankless water heater. On a cold day like today endless hot water sounds aaaahhh! Ask Lewster what model would work safely for your Moho.
Hope you get a good solution quickly.
Paula
Old 01-30-2016, 12:38 AM   #4
Denver , Colorado
Guys,
I'm just getting around to updating my post from the trip. Thanks to all of you for the help on random issues that popped up. The issues with the water heater turned out to be power loss to the switch. A light switch was messed with the day we left and power to the water heater was jumped off of that wire. The leak near the tank was a loose clamp from the hose that circulates antifreeze to heat water while driving. Once we robbed power again it was fine. When it comes time to replace the tank ill definitely go tankless.
Cody
being frugal with hot water best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 09:14 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
